Heater problem please help!!!! - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 02-01-2010, 09:48 PM Thread Starter
Date registered: Jan 2010
Vehicle: 1995 c280
like it said in my title i'm having a problem with my heater fan or something the blows the air... when it first started i thought its a small problem after few days it didn't start at all i tried to open the hood and chech if its a fuese problem but all the fuses are right... i closed the hood with a hard push because i was mad i went into the car and the heat was on ...turned it off and tried to turn it back on didnt work again... i opened the door and closed it the heat worked again.... the next day didn't work with the funny way by closing the hood and door... i knew that theres a big problem after driving about 10 minutes the fan worked for about 15min and went off again ... now it worked for 10 min and went off if i turn beams on the red lights on the ( heat bottons) don't know what the real name is haha you can see that the red light is weak turn the beams off the red light is strong again.... Can anyone help me with this situation please ????? I already had alot of problems with this car and spent alot of $$$$$ so please any suggestions ???
1995 c280 118k Miles
mikhail.abraham is offline
post #2 of 8 (permalink) Old 02-02-2010, 10:23 AM
Date registered: Jun 2009
Vehicle: 1999 C280 210k miles
My heater / AC blower worked intermittantly for about a year. Sometimes it was great, other times I had no air /heat for days. I used to bang the cover under the passenger side dash - the jolt would sometimes get the blower to rotate again. I'm guessing you have a similar problem and the jolt from the hood, doors, road, etc. get the blower to work for a few minutes at a time.
The problem can be in the blower motor or the resister pack. These are separate parts.
My problem was the blower motor. Bought replacement on Partsgeek for less than $200. Its an easy installation, search the forum for directions.
Been working great for the past 8 months.
gmascoli is offline
post #3 of 8 (permalink) Old 02-07-2010, 11:15 AM
I'm having a similar problem that started two summers ago. It stated during the summer when the AC would not blow then later during the fall when I needed heat it wouldn't blow either. It seems to work on and off and I have noticed it may come on if the fan it set to 2 or below for some reason. When I really need it to run defrost it will not work. After reading the forums I am going to remove the fan and see if I can get it to work. I do recall a high winning noise on occasion like a leaf stuck in it before it stopped working.
jslaughter is offline
post #4 of 8 (permalink) Old 02-07-2010, 01:53 PM
I just just taking a look at the fan motor ...
I had the dealer look at my fan during my B Service. They charged me over $200 just to diagnose this. The dealer stated they had to remove a lot of stuff to check the motor and it needed to be replaced for an additional $450. I passed and said I'll hold until I have some cash.
I have been on these forums today so I decided to take a look under the passenger side dash. Wow this is so easy! I found some leaves stuck in the motor so I removed them and cleaned the plastic cover that was very dirty. Removed the air filter element and found even more leaves.
Turned on my fan to setting five and guess what? Air shooting out my vents! The fan appears to be working perfect.
Why is the MB Dealer not servicing my car for such an easy fix? While I'm thrilled about this forum and my fan working I am also really displeased with the local MB dealer. I'm thinking ... did they really even service my car? I'm thinking the B service is a quick 19.95 oil change and nothing else.
post #5 of 8 (permalink) Old 02-07-2010, 08:21 PM
Like I said, this need not be a major cost to repair. You got lucky that is was leaves jamming your fan, but you gotta wonder how all that junk is getting in there. You might want to find another parking spot!
Mikhail appears top have another problem based on his description. Dont' know how he's making out with the new blower or resister pack.....
gmascoli is offline
post #6 of 8 (permalink) Old 03-05-2010, 04:03 PM Thread Starter
Vehicle: 1995 c280
It was the brushes... i took out the springs and got taller once lol and now its working .....nice trick huh?
post #7 of 8 (permalink) Old 01-24-2015, 06:37 PM
KWD
Date registered: Jan 2015
C320 heater / AC control problems
My 2001 C320 heater blows so hot.... all the time! I cannt seem to control the fan speed, temp with the controls. I also hear a loud clicking (for years) from the center dash. The clicking even continues after the key is off... any suggestions?
KWD is offline
post #8 of 8 (permalink) Old 01-30-2015, 05:14 AM
Date registered: Mar 2007
Quoted: 2 Post(s)
My blower motor has gone dead too, brushes totalled.
I just wanted to point out that there are different blower motor versions, i'm guessing RWD and LWD, because my mechanic ordered a replacement which was mirrored to the original one.
Jomzo is offline
    Heater problem. bielefeld280se W126 S,SE,SEC,SEL,SD,SDL Class 19 01-25-2015 03:35 PM
    Heater Blower Problem Fixed: R/R Heater Blower tracer342 R170 SLK-Class 0 01-28-2010 08:03 AM
    heater problem S-BOPOH C215 CL-Class 4 08-29-2009 08:57 AM
    Heater problem creates another problem Wizz190E W201 190-Class 0 03-19-2008 02:54 PM
    Heater Problem Alejo Russo W123 E,CE,D,CD,TD,TE Class 4 06-16-2003 12:38 PM
