Hi my 1996 c220 with 4 speed vacuum controlled 722.4 trans is slipping almost catastrophically in all gears including reverse. The car will go trough all the gears but with throttle only half way will slip into what seems to be neutral. I checked the transmission's repair manual but there is no band or clutch that operates in all gears and I seriously doubt that all bands and clutches went out. The car has 80k miles.
I checked the fluid, the level is normal. I removed the transmission pan, oil was black but absolutely clean with:surrender: no metal flakes or some other residue. I checked B2 piston which is also fine. Cleaned the valve housing but it was clean already, I haven't seen anything that is stuck. So now I need you help :bowdown:, what the hell is wrong? Is my pump gone and I don't get enough pressure, what is even the likelihood of that happening to these transmissions? I searched high and low but still haven't found the answer.
