How to replace radio antenna - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 11-18-2009, 01:38 AM Thread Starter
Date registered: Nov 2009
Vehicle: W202, 1995, C200 Sport
How to replace radio antenna? The one placed left of the boot lid. Couldn't find any mention of this in Haynes. And, where to buy online, Europe preferably...?
haz_norway is offline
post #2 of 18 (permalink) Old 11-22-2009, 10:26 AM Thread Starter
Anyone?
I found some antennas on ebay, but do I really need the whole thing when it's just broken off on the tip? Maybe I will need it, because I suppose the antenna is meant to go up and down when starting the engine and turning it off?
This any good? Power Antenna Kit Mercedes W140 W126 W201 W113 W202:eBay Motors (item 140360753756 end time Dec-17-09 18:38:23 PST)
post #3 of 18 (permalink) Old 11-22-2009, 04:16 PM
Pringles21's Avatar
Date registered: Aug 2009
Vehicle: 1997 C280
Here check this thread out.
http://www.benzworld.org/forums/w202...0-antenna.html
You don't need the whole thing with the motor unless the motor is also broken.
Here's an antenna MERCEDES BENZ POWER ANTENNA MAST C230 C280 W202 SL320:eBay Motors (item 290317436370 end time Dec-10-09 18:54:34 PST)
and another 94-98 MERCEDES W202 C230 C280 OEM POWER ANTENNA MAST 95:eBay Motors (item 250493587174 end time Dec-03-09 22:18:03 PST)
I don't know if the one you posted is good. Good luck.
Pringles21 is offline
post #4 of 18 (permalink) Old 11-23-2009, 01:15 AM Thread Starter
Thanks, that helps alot. But instead of dissecting the whole antenna and motor in the trunk just to find out if the motor need replacing, isn't there a better way to easily check if the enigne is dead? Because the state of the whole radio antenna deal right now is that the tip is broken off and it doesn't move up or down when I start the engine/ shut off. I think this smells of motor-replacement.. no? And that guide should be sufficient for doing it myself a saturday morning
post #5 of 18 (permalink) Old 11-23-2009, 01:41 AM
Pringles21's Avatar
Vehicle: 1997 C280
Yeah it sounds like your mast motor is dead. You can try the one from ebay if you'd like and tell us if it's good otherwise get an oem new or used. Good luck and I hope I helped.
post #6 of 18 (permalink) Old 11-23-2009, 02:43 AM Thread Starter
Yup you did help, I basically figured out that I might as well just go for the whole package, so right before our morning meeting here at work - I logged on to eBay and got this:
Not OEM but hopefully it works. There was one other buyer who'd left a feedback on the same seller with this exact product and said it worked fine.
edit: I only found this OEM, but it was $69 http://cgi.ebay.com/ebaymotors/94-00...item27ad056154
post #7 of 18 (permalink) Old 11-23-2009, 10:26 AM
eundaddy's Avatar
Vehicle: 1998 C43
Send a message via AIM to eundaddy
are you sure that ur motor is broken? does it make any noise when you turn the car on? maybe the broken tip is getting the motor stuck?
eundaddy is offline
post #8 of 18 (permalink) Old 11-23-2009, 12:04 PM Thread Starter
well no, I haven't had the chance to look at this and when I first have the time to fix the antenna I might aswell have both a new antenna and motor
post #9 of 18 (permalink) Old 03-08-2010, 02:52 PM
roadster49's Avatar
Date registered: Nov 2007
Vehicle: 1997 Mercedes S500 Coupe
mine quit going up today, makes noise to start but then stops...isit the motor or mast?
roadster49 is offline
post #10 of 18 (permalink) Old 03-08-2010, 07:31 PM
Triggerhappy's Avatar
Vehicle: 1978 240D
Quoted: 41 Post(s)
DO NOT BUY THIS! I got one and it's not for the w202, not the same size as the one in the car, and basically none of the parts fit at all. (I sunk $50 into trying to repair my antenna a while ago and finally gave up).
Triggerhappy is offline
    Can I replace Becker stock radio with aftermarket radio? PPrash W210 E-Class 2 07-17-2007 06:38 PM
    Replace Broke Antenna MisterKev W124 E,CE,D,TD Class 3 06-12-2006 07:56 PM
    XM radio antenna installed inside dummy MB antenna keywestc320 W203 C-Class 1 04-12-2005 06:26 PM
    Does anyone know how to replace the radio antenna cable? UncAl W163 M-Class 4 08-20-2003 02:12 PM
    SL Antenna and European Bumper Radio Antenna - Buy Group Peter - San Francisc R170 SLK-Class 9 04-12-2002 10:50 PM
