» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W202 C-Class
Old 11-16-2009, 01:55 PM   #1 (permalink)
Date registered: Nov 2009
BAD Vibrations. Transmission?
I have a 2000 C280 with about 134,000 miles on it. When I come to a stop, the entire car shakes very badly. I believe it is the transmission mounts. Here is why:
1. The vibrations only occur when at a complete stop. Once I accelerate, the vibrations cease. This leads me to believe that it isn't a steering/alignment issue.
2. When at a stop, the vibrations cease if I shift into neutral. Once I shift back into drive, the vibrations resume. This leads me to believe that it is not an engine mount problem.
Thoughts anyone? Has anyone had this problem? Am I wrong? Thanks in advance.
Austinb86 is offline   Reply With Quote
Old 11-16-2009, 04:32 PM   #2 (permalink)
Date registered: Jul 2007
Have you tried checking the mounts?
marvinstockman is offline   Reply With Quote
Old 11-16-2009, 04:53 PM   #3 (permalink)
liquidusculade's Avatar
Date registered: May 2008
Vehicle: 95 C220
it sounds to me like it is the engine mounts. mine were worse in drive than park.
it would be smart to go ahead and change out the trans mount when you change out the motor mounts though.
i would also check your flex discs, to see if they are in good condition. these will usually vibrate when moving though if they are badly worn.
liquidusculade is offline   Reply With Quote
Old 11-16-2009, 05:01 PM   #4 (permalink)
Thanks. If the engine and trans mounts are bad, are they expensive to replace and is that something that I can do with basic tools? Or will i need to take to it a mechanic?
Old 11-17-2009, 12:41 AM   #5 (permalink)
Date registered: Sep 2008
Vehicle: 1983 Mercedes 300DT 301500 miles
a vacuum leak could cause that. I am pretty sure it is a vacuum leak if it happaned all of a sudden.
1983 Mercedes 300D Turbo 307 700 miles. Spare car.
1994 Mercedes C220 converted to run on Natural gas.
Bought at 138 200 miles, current odometer: 208 300 mi
1994 Mercedes C280 140,800mi. my wifes
Tedd300DT is offline   Reply With Quote
Old 11-17-2009, 01:19 AM   #6 (permalink)
Vehicle: 95 C220
it could be a vacuum leak. do you hear any hissing under the hood?
i think at 134,000 miles the motor mounts are overdue if they havent been changed.
i just changed mine out myself at 138,000.
there are a few good writeups on here about diy. i had a lift to use when i did mine. you will have to raise the engine to replace the mounts.
Old 11-18-2009, 03:03 PM   #7 (permalink)
oberoi's Avatar
Date registered: Mar 2006
Vehicle: SLK230 (2000) C180/230E/280SE
Mounts are relatively easy and agree with earlier post that not a bad idea to do anyway at your miles, although it sounds like something else.
Check for fluid leak marks from the small holes in the mount - also check when reversing (esp up a hill or driveway) - usually evident with a grumbling sound.
Oberoi
oberoi is offline   Reply With Quote
Old 11-25-2009, 01:03 PM   #8 (permalink)
Klasse220's Avatar
Vehicle: C220 Elegance
Hello all you ppl out there, ive got a c220 elegance 97. Everything is perfect except for a jerk in the automatic transmission when the gear changes from 1st to 2nd. also, the accelerator is quite hard aswell. Just wanted to ask that is this normal for all W202 c class cars or is this an exception. Thanks
Klasse220 is offline   Reply With Quote
Old 11-25-2009, 06:51 PM   #9 (permalink)
britonj's Avatar
Date registered: Feb 2008
Vehicle: 2000 c230k
having same problem, changing all fuel system parts (maf, plugs, coil pack, wiring,) and A sercive will be done friday will let you know if that fixs mine
i dont think its the mounts because it only happens like 30 percent of time, and it will continue on every stop unless i restart the car which what leaves me to believe it is something else....
britonj is offline   Reply With Quote
Old 11-26-2009, 11:38 AM   #10 (permalink)
Klasse220's Avatar
Originally Posted by britonj View Post
having same problem, changing all fuel system parts (maf, plugs, coil pack, wiring,) and A service will be done friday will let you know if that fixs mine
alrite thanks britonj
Bad Vibrations davellew New Member Introductions 2 11-12-2009 10:17 AM
Help! 89 300E with bad vibrations! jerryls W124 E,CE,D,TD Class 13 09-08-2009 07:55 PM
Bad Vibrations mrose902 W203 C-Class 0 01-14-2008 04:28 PM
BAD Vibrations RSPINAJR W210 E-Class 28 04-19-2007 08:31 AM
Bad Vibrations 4x4rancher G-Class 8 10-03-2005 01:30 PM
