C230K trans code p0730 - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 07-30-2009, 10:16 AM Thread Starter
Date registered: Jul 2009
Vehicle: 2000 Mercedes C230 Kompressor, 2004 C320 4Matic
Hello all. I am having trouble with my transmission. It is in "limp" mode with codes p0700, p0730. I pulled the trans pan, valve body, replaced the contactor plate. This was "supposed to repair the problem. I drove the car, still same. I understand that I cannot clear the codes myself properly, they are still active with a check engine light. My question is this, If the car is actually repaired at this point, will the latched codes in the TCM alone cause the "limp" mode condition I am experiencing? And will the problem go away when properly cleared?
Please help! Thanks in advance!
Doug
dieselman01 is offline
post #2 of 18 (permalink) Old 07-30-2009, 07:08 PM
xvvvz's Avatar
Date registered: Sep 2006
Vehicle: '99 2.3L Kompressor
Did you try resetting things by disconnecting the battery for 30 seconds or so? You will then need to resync your windows, sunroof and have your radio code.
Did you check the connector and harness to me sure you were not getting a leak at the connector that was wicking toward the TCU?
xvvvz is offline
post #3 of 18 (permalink) Old 07-30-2009, 07:37 PM Thread Starter
I looked into the harness from the trans connector. It looked ok. Is the TCU located near the right side of the tunnel on the passenger side floor area? I would like to pull the connector at that end and check it there also.
What about the code causing limp mode even though the trans may be fixed???
post #4 of 18 (permalink) Old 07-30-2009, 07:38 PM Thread Starter
I did the battery disconnect also earlier. Code goes away, problem remains. Code returns after a minute or two
post #5 of 18 (permalink) Old 07-30-2009, 08:26 PM Thread Starter
No wicking at TCU
post #6 of 18 (permalink) Old 08-02-2009, 05:05 PM Thread Starter
No speed signal from N3 rpm sensor
I monitored the N3 wires on that sensor, it never generated any frequency, not showing any speed signal for the TCU. That`s probably why the p0730 gear ratio code. Which sensor is P3? Turbine speed? Why wouldn`t it register anything? I replaced the contactor plate already.
Doug
post #7 of 18 (permalink) Old 08-02-2009, 05:45 PM
xvvvz's Avatar
If it were the turbine, my code lists looks like that should throw a 715.
I have never been able to find an reference to matching trouble codes with solutions within the WIS. If anyone knows info. on this, please speak up! I am guessing they don't feel the need to do this since a stealership mechanic has the SDS to hook up and read everything. The Mitchell CD just says that you need to read the DTC memory from the TCU itself, so that is no help.
xvvvz is offline
post #8 of 18 (permalink) Old 08-02-2009, 05:51 PM
xvvvz's Avatar
I also checked Haynes and it is pretty useless for transmission stuff.
D-man, please update your profile so we know the year and model of your car.
xvvvz is offline
post #9 of 18 (permalink) Old 08-02-2009, 06:15 PM Thread Starter
Just found RPM signal N3 not putting anything out while driving in limp mode. N2 looks like input speed signal as per HZ on meter VS engine rpm`s. N3 is Dead. Resistance through circuit looks ok, which scares me...like mechanical failure. Is this turbine speed I am attempting to see or output speed? Could there be a key sheared in trans on pulse wheel or something else going on. Just ohmed out harness between trans and TCU, looks ok. Adapter plug is suspect, will remove it tomorrow when it cools down and check it.
Thanks for the help all, When a solution is reached, I will elaborate for all you to reference.
Doug
post #10 of 18 (permalink) Old 08-02-2009, 07:44 PM
bmeister's Avatar
Date registered: Oct 2007
Vehicle: 1998 c230 170K
Quoted: 9 Post(s)
solenoid valve, contact finger
In the manual it mentions bending the solenoid contact finger not sure if they mean the contacts on the plate or actually in the valve body itself. There are some other things mentioned such as metal shavings, filter, and fluid level but sounds like you already checked that out. If you like just scroll down to page 73+74. Hope this helps. B
bmeister is offline
    P0730 Incorrect gear ratio cougs_83 W210 E-Class 5 11-22-2012 01:14 PM
    B- Service and Code Clear '04 C230K GonzBenz9910 W203 C-Class 0 04-21-2008 02:37 PM
    P1700 Trans. code cjshade W202 C-Class 3 01-06-2008 03:50 PM
    2002 C230K...P0301 code dsilvar W203 C-Class 3 07-06-2006 07:34 AM
    C230K Trouble code Ghee W203 C-Class 1 03-26-2006 09:53 AM
