Vacuum line replacement? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-18-2009, 09:27 PM Thread Starter
jtetterton's Avatar
Date registered: Jul 2009
Vehicle: 1997 Mercedes-Benz C230 White 217,000 miles
Send a message via AIM to jtetterton
Please reference the attached gif file...
While inspecting the vacuum lines on the front of the engine, I found this line damaged and have temporarily repaired it...
I need the pipe labeled "br" that you see to the right of the check valve (128).
Also, on the same diagram, can anyone give me the part number for the item Y58/1 ?
While i'm working on this system, is there anything else that you can recommend that I replace?
Thanks!
Jason
New benz owner
1997 C230 Polar White, 217,000 miles and still running strong!
jtetterton is offline
post #2 of 4 (permalink) Old 07-19-2009, 09:10 AM
bmeister's Avatar
Date registered: Oct 2007
Vehicle: 1998 c230 170K
Quoted: 9 Post(s)
MOT Purge Valve
Most all benz parts have part #'s on them, if you can't find the hose online I would suggest just taking the car to the benz parts area, pulling the hose off and bringing it up to the parts counter. Might be 5 bucks.
This is a good place to look up part #'s
MERCEDESBENZGENUINEPARTS.COM
Is this the other item you are referring to? (see pic.) If so why do you plan on replacing this part? B
Name:	purge valve.jpg
bmeister is offline
post #3 of 4 (permalink) Old 07-19-2009, 04:24 PM Thread Starter
jtetterton's Avatar
That looks like the part, is that the purge valve? I was looking over old service records that the owner provided me and on one of them, the mercedes mechanic recommended that the pure valve be replaced to rectify the CEL. They didn't mention the code, but the previous owner told me the light always came back on several days after he left the shop and he didn't worry about it.
I have it checked when I bought it and the code is P0441 (i think), and it referenced the purge valve or emissions system.
Jason
New benz owner
post #4 of 4 (permalink) Old 07-19-2009, 07:07 PM
bmeister's Avatar
Quoted: 9 Post(s)
I would get the new hose, clear the code and see if the CEL comes back, if not try cleaning the part, might just be gummed up. Here are some prior posts that may help. B
http://www.benzworld.org/forums/w202...-solenoid.html
http://www.benzworld.org/forums/w210...rge-valve.html
bmeister is offline
    Pictorial DIY: M104 - EGR vacuum line replacement - OBDII Code P0400 texholdem W210 E-Class 0 04-01-2008 08:41 PM
    Low vacuum on booster line. Do I need to rebuild vacuum pump? dentate gyrus W123 E,CE,D,CD,TD,TE Class 6 04-18-2007 06:58 PM
    same vacuum line? greginland R/C107 SL/SLC Class 5 01-30-2007 06:53 PM
    Vacuum line Minkoff W126 S,SE,SEC,SEL,SD,SDL Class 6 05-11-2006 10:03 PM
    Vacuum line - if I cut the line to the doors and trunk, will it harm anything else? 240-John W123 E,CE,D,CD,TD,TE Class 5 01-26-2006 02:53 PM
