I have now attempted to get the fans going by disconnecting the temp sensor from the termostathouse, but the fans did not come to life.
I have attatched some images, one is of the control module inside the driver-side wheel arch the other is the relay I think could control the fans and the third is the aux fans themselves.
i didnt touch the control module.
the air/temp sensor looks like this from what i remember
check the diagram on page 1. see whats goin one with yours i have a c220 and mine matches exactly with the diagram the 1st poster put up there.
So u know, when I disconnected the sensor (the one on the driver side under the plastic benz logo right above the water pully, my fans came on. but later i came to find out anyway that my relay 1 fuse was blown anyway. i dont know if it was the level 2 fan that came on, but i CAN tell u both them things was turning, and it was loud as hell, even though my relay fuse 1 ws blown. i dont know what wouldve happened if relay 2 fuse was blown as well. the fuse sits right inside of the relay as described in the link. it was a 15amp. i replaced it with 25. problem solved.
I don't have that type of relaybox, I don't have the relays for Hi/Low settings to aux fan. As I understand the cable harness for the air condition and the headlamp cleaning system is the same, I found an illustration of that here Google Translate and I have noticed that the headlamp cleaning system also is malfunctioning, the headlamps should be cleaned the same time as the windshield is cleaned, right?
But it does'nt work for me, so I think i'll have to examine the cable harness and try cleaning the contactareas.
I have finally found the solution to the problem. The aux fan relay/controlmodule I found in the driverside wheelarch is most likely the malfunctioning part. I have attached a picture below and made an excplanation of the pins and connections on the cable.
#1 - I measured this with a voltmeter, it indicated 13,84 V and it was the same regardless of the engine running or the ignitionkey placed on 0. So this is the powersource to the module.
#2 - This was connected to the left aux fan, I tried jumping the wires from #1 to this one and the fan started spinning with full blast.
#3 - Same as #2 but for right aux fan.
#4 - Ground
#5 - I measured this with ignitionkey set on 0 and the voltage was 0 also, then I started the engine with AC on and the reading was 0,15 V but I kept reading it and after a short while it showed 10,84 V so I guess this is when the fans should start spinning, but they did'nt.
I also tried attatching wires on the #1, #4 and #5 pin and their respective contacts on the cable, then I measured if pin #2 or #3 had any voltage but it was zero point something.
So I took the module away from the car and opened it at home, there was quite much corrosion on the pins to one of the microsprocessors inside the module, so I am going to buy some electronics cleaning spray tomorrow and try cleaning the module to see if it works.
For now I have an on/off switch inside the car that controlls the fans, it is fused with a 15A fuse (The fuse in the fusebox is 30A and I replaced that with a 20A fuse just to be safe.) this is because i'm getting tired of the whole sauna experiense when driving in stop and go traffic, I allways have to turn the AC off and turn the heater on full heat.
Thanks for the help everybody, I will report if the electronicsspray helped at all
AC Pressure Switch; On Receiver Drier; 3 Spade Connector
Denso P/N 1408300072
I know I have to drain the refrigerant before replacing anything on the AC system. Since I already have a new dryer (acts like a filter for the AC system), all I need is the AC temp sensor (which also mounts to the dryer with the pressure sensor) to make it complete
