1998 C280 Tranny Won't Shit Gears - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 02-15-2009, 08:05 AM Thread Starter
Date registered: Feb 2009
Hello, I drive a 1998 automatic c280, The problem is, my car won’t shift out of 2nd gear when I drive it, A shop told me I need a new transmission,. So I got it put in, yet it’s still having the same problem. What could be wrong
WNichols is offline
post #2 of 18 (permalink) Old 02-15-2009, 08:24 AM
00_230_K's Avatar
Date registered: Jul 2008
Vehicle: 2000 c230 kompressor
ur stuck in limp home mode, search it up lots of info, did u scan for codes?, it could be just a loose wire somewhere
00 C230 Kompressor
Hamilton, Canada
00_230_K is offline
post #3 of 18 (permalink) Old 02-15-2009, 09:05 AM
liquidusculade's Avatar
Date registered: May 2008
Vehicle: 2001 CLK55 AMG
so are you going to get your money back for the new transmission haha. damn. as recommended, get the codes read.
liquidusculade is offline
post #4 of 18 (permalink) Old 02-15-2009, 09:06 AM
bmeister's Avatar
Date registered: Oct 2007
Vehicle: 1998 c230 170K
Quoted: 9 Post(s)
Wild goose chase
Correct me if I am wrong, your transmission was and still is having 2nd gear issues and the tranny has been changed....If so did they ever retrieve tranny codes are give you any resolution on this? If not you will have to have a SDS test done, period.
I am attaching a pdf. again about tranny issues that basicly will give you an idea of how complex this type of issue can be. Well it could be many things to answer your Q. The tranny besides the computer modules on these cars are probably the most complex components to deal with.
Here is a quote perhaps pertaining to what you described from the pdf.
Transmission shift point delay:
"The 2nd to 3rd gear upshift on some models is delayed 60-80 seconds to enable catalytic converter to reach its operating temp. quicker. Shift point retard solenoid is energized by CIS-E shift point or AIR MASS Sensor control unit through transmission shiftpoint (upshift) retard relay. "
Apparently there is a vac module involved, the computer, and the Air mass meter or MAF we all know to well, not to mention all the internal mechanics that come into play.
If you did indeed have someone install a new tranny and go through with all that expense is bring it back and them, but it sounds like whomever it was does not have SDS software so you will at least need that info before you can proceed.
I would be extremely steamed if I were you if this was just another issue of a MAF going bad. Hope you get this resolved, B
bmeister is offline
post #5 of 18 (permalink) Old 02-15-2009, 12:36 PM
cjshade's Avatar
Date registered: Nov 2007
Vehicle: 96' C220
Post 722.6
I believe that WNichols Tranny is the 722.6 which is the Computer controlled box. Much more complex even that the 722.3 and .4 that the PDF covers. The same theories apply for certain functions as bmeister noted.
One common problem on the 722.6 is the Large Electronic Connector gets contaminated with fluid from a leaky seal. This causes all kinds of crazy problems including Limp Home Mode.
Good luck and please let us know how you come out!
Here's an extra "f" to put in your Thread title!
C as in 220
cjshade is offline
post #6 of 18 (permalink) Old 02-15-2009, 01:10 PM
'91 300CE's Avatar
Date registered: Jul 2006
Vehicle: 2002 ML320
I would throw an absolute fit for that shop telling me I needed a new transmission and charging me for one!!!!!!!!!!... AND what are you doing going to a NON-MB shop for anything transmission related!?!?
2005 BMW 325Ci - Sport, Premium and Cold Weather Pkgs
2000 C230K -- Desert Silver Metallic -- 113,000 miles -- Sold
2002 ML320 -- Alabaster White
1991 300CE -- Blue Black Metallic -- 129,000 miles -- Sold
1981 300SD -- Classic White -- 190,000 miles -- Sold
1977 240D -- Over 300k miles (Wrecked) -- My 1st car
2006 Porsche Cayenne S - Dad's
2004 Porsche 911 Turbo S
'91 300CE is offline
post #7 of 18 (permalink) Old 02-15-2009, 01:46 PM
LAMF's Avatar
Vehicle: 96 C36, 87 Turbo'd 190E 2.3-16, 86 SC'd 190E 2.3-16, Brabus'd C32
limp mode FTW!!!
87 190E 2.3-16 Cosworth- Track car-Getrag, short shift, delrin, 95a poly, Euro'd, 2 tone Recaros, custom suspension, EFI w/ Megasquirt, cast iron headers, Garrett turbo...
86 190E 2.3-16 Cossie-Old beater Getrag, slammed on BBS' Mosselman ECU, Eaton M62 SC
03 C32 ///AMG - Daily- designo edition, command, fulll Brabus CF interior, CF lips mirrors spoilers ect, and enough engine mods to destroy 911's
LAMF is offline
post #8 of 18 (permalink) Old 03-12-2009, 06:38 AM Thread Starter
Ok I got the car back, it's sitting out front, do you guys know any techs here in the washignton dc area, or will i have to drive all the way to the shop & get over charged for a scan
WNichols is offline
post #9 of 18 (permalink) Old 03-12-2009, 07:14 AM Thread Starter
WNichols is offline
post #10 of 18 (permalink) Old 03-12-2009, 07:21 AM
C280Stevo's Avatar
Date registered: Mar 2009
Uncertain.
I just bought the same model year C280 as you. That eBay posting does NOT list our C280 as one it will be compatible with. Did you notice that? I hope that's a typo, cuz for $28.00 I will be ordering one too. What do you experts think?
p.s. To keep things light, may I suggest alternatively that you try Immodium AD for the tranny issue?
C280Stevo is offline
    1998 C280 JonzBenz General Mercedes-Benz 0 07-17-2008 10:56 PM
    1998 E300 TD replaced tranny 8/07 gianigreco For Sale/Wanted/Trade/Giveaway 0 05-14-2008 11:59 AM
    help with C280 tranny ? dn9979 W202 C-Class 21 05-10-2008 08:53 PM
    1998 e320 tranny service w210 W210 E50 AMG, E55 AMG 3 11-20-2004 10:28 AM
    GEARS IN TRANNY Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 2 03-31-2002 11:30 PM
