1995 c280 Oil leak help - Mercedes-Benz Forum
post #1 of 30 (permalink) Old 01-07-2009, 02:09 PM Thread Starter
Date registered: Nov 2008
Hey there. I recently replaced the water pump in my c280 and noticed a pretty bad oil leak coming from the upper part of the left side(looking at the engine). I took it to a MB mechanic who told me it was not my head but my distributor housing seal. Has anyone been faced with this problem? If not, any links on pulling out the distributor would be appreciated.
Thanks!
Anthony
Spitstix is offline
post #2 of 30 (permalink) Old 01-07-2009, 04:13 PM
bmeister's Avatar
Date registered: Oct 2007
Vehicle: 1998 c230 170K
Quoted: 9 Post(s)
Do you mean the Cam mag?
Thanks!
Anthony
Take a pic of the area if you can and post along with filling out your mileage profile and such. See pic, these cam mags are known to leak down the front of engine, mine did a while back, its a replace only item, they will leak internally and wick oil through the plug. B
bmeister is offline
post #3 of 30 (permalink) Old 01-07-2009, 07:17 PM
Metafly's Avatar
Date registered: Mar 2008
Vehicle: 1986 190D 2.5 5 Speed
I am checking this area too. It is so accessible. So, per your suggestion B, I checked the Cam Mag today and noticed a lot of grime around the plug and on the underside of the magnet. However, I did not notice any wet. Was yours/should the leaking very noticeable?
Michael
1986 190D, 5 Speed
1985 Porsche 928, 5 Speed (32v)
1980 Porsche 928, 5 Speed (16v)
So Cal
Metafly is offline
post #4 of 30 (permalink) Old 01-07-2009, 08:54 PM Thread Starter
Okay sounds good. I'll take a pic tomorrow and post it with mileage. Thanks
Spitstix is offline
post #5 of 30 (permalink) Old 01-08-2009, 07:52 AM
liquidusculade's Avatar
Date registered: May 2008
Vehicle: 2001 CLK55 AMG
mine had grime on it too, i was attempting to clean my engine up so i can notice if any leaks are present... mine may leak slowly, is it bad if it leaks?
liquidusculade is offline
post #6 of 30 (permalink) Old 01-08-2009, 04:37 PM
Date registered: Jul 2007
Is there oil on the ground? Is the bottom of the engine coated with oil. If not, I wouldn't worry about it.
marvinstockman is offline
post #7 of 30 (permalink) Old 01-08-2009, 04:58 PM
Metafly's Avatar
Yes mine is. I don't mean to threadjack but I would like to know how much oil to expect from the camshaft adjuster/magnet if it is faulty. Like, "wow, this shit is f'd up" or "I have a lot of black residue, but no wet oil". Thanks.
Michael
1986 190D, 5 Speed
So Cal
Metafly is offline
post #8 of 30 (permalink) Old 01-09-2009, 07:09 AM
Fusion.C280's Avatar
Vehicle: '94 C280 US Spec
Quoted: 2 Post(s)
Common problem on the 280 inline 6.
It leaks under the head, a bit further back than where the mag is.
I'm not sure exactly what they changed on mine but it wasn't expensive.
It's not the head gasket though.
Fusion.C280 is offline
post #9 of 30 (permalink) Old 01-09-2009, 08:56 AM
i have a 220 and its not leaking at the head gasket, its defenitely around the cam mag. i dont really see oil, just black residue like metafly down the front of my engine, im guessing at some point it was oil, now its oil dirt lol. there is no oil on the bottom, im in the process of cleaning it up so i can see if it returns.. maybe it was just a previous problem that was never cleaned up.
post #10 of 30 (permalink) Old 01-09-2009, 03:13 PM
Metafly's Avatar
Do you remember where exactly? Thanks. Michael
Michael
1986 190D, 5 Speed
So Cal
Metafly is offline
97 C280 Oil Leak as Well lca13 W202 C-Class 2 03-24-2008 09:48 PM
1995 C280 Oil type & capacity? BadBoy W202 C-Class 6 05-14-2007 07:24 AM
97 C280 Oil Leak Guest (MBNZ) W202 C-Class 1 07-05-2002 02:17 PM
C280 Oil Leak - Headgasket Issues Guest (MBNZ) W202 C-Class 4 05-22-2002 10:22 PM
1995 C280 pesty oil leaks Guest (MBNZ) W202 C-Class 0 02-02-2002 08:44 AM
