how to change the tranny "pilot bushing" (leak) - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 11-25-2008, 02:42 PM Thread Starter
baknforth101's Avatar
Date registered: Feb 2008
Vehicle: 2000 C230 komp.
hey i have a 2000 c230 with about 60,000 miles . i changed the tranny fluid/filter about 3,000 miles ago and now i am noticing a small leak . so, i got under the car i realized it was something just above the pan on the front passenger side. it was round and looked to be screwed in possibly. so, i called the dealer and they said it was a common problem and was called the pilot bushing. i am having trouble finding anything that has that name, but i can always get it at the dealer. they want $130 to install it so i am hoping that someone here can give me more info and some advice about how to change this and where i can buy one myself to save a bunch of $$. any info would really help , thanks alot to all
baknforth101 is offline
post #2 of 12 (permalink) Old 11-25-2008, 03:28 PM
Metafly's Avatar
Date registered: Mar 2008
Vehicle: 1986 190D 2.5 5 Speed
You have an auto trans correct? Probably a rear main seal leak. Pilot bearings, as far as I know, are in manual transmissions.
Michael
1986 190D, 5 Speed
1985 Porsche 928, 5 Speed (32v)
1980 Porsche 928, 5 Speed (16v)
So Cal
Metafly is offline
post #3 of 12 (permalink) Old 11-25-2008, 03:35 PM Thread Starter
yes it is an auto and i did find the part on autohauseaz.com and it is called the tranny bushing/oring combo. about a 6 dollar part. this is definitely where the leak is. thanks
post #4 of 12 (permalink) Old 11-25-2008, 04:35 PM Thread Starter
i guess i should also ask how much fluid i am going to lose when i change this, without removing the pan, that way i can get some with the part. thanks again
post #5 of 12 (permalink) Old 11-25-2008, 05:18 PM
Metafly's Avatar
Just put back in what comes out.
Michael
1986 190D, 5 Speed
So Cal
Metafly is offline
post #6 of 12 (permalink) Old 11-26-2008, 09:36 AM Thread Starter
i have read on here that i should use electrical contact cleaner on the parts before instaling the new one. is this recommended?
post #7 of 12 (permalink) Old 11-26-2008, 10:09 AM
cjshade's Avatar
Date registered: Nov 2007
Vehicle: 96' C220
Post Contact Cleaner
You should be OK with that. The point is to make sure the parts are clean.
You probably will not lose much fluid since what you are removing is above the Pan.
Is this the Shifter Bushing you are replacing?
Good Luck!
C as in 220
cjshade is offline
post #8 of 12 (permalink) Old 11-26-2008, 10:51 AM Thread Starter
it is called by the dealer the pilot bushing but kind of looks like a black plastic shot-glass shaped item that is just above the pan on the front pass. side . you rotate a white piece of plastic and remove the harness with 13 pins and then clean the electrical connectors and reinstall. hopefully i dont lose too much fluid cause i only have 1 extra quart and quite a bit has already leaked out due to the o-rings leaking. i think i have this figured out due to the AWESOME info both here and online in general (i did call my local dealer as well, not that they tell the truth) you guys on here kick ass
post #9 of 12 (permalink) Old 11-26-2008, 10:59 AM
cjshade's Avatar
Vehicle: 96' C220
Post Wiring Plug Seal
So is it the seal around your Wiring Harness Plug? That is a common problem and often causes serious Tranny failures when it becomes wet with fluid.
So they call it a Pilot Bushing, that's good to know. Usually a pilot bushing is in a Manual Clutch as Metafly stated.
Good catch!
You saved yourself a bundle by catching this early and doing it yourself!
C as in 220
P.S. Sometimes we take down names too!
cjshade is offline
post #10 of 12 (permalink) Old 11-26-2008, 12:35 PM Thread Starter
the only thing i am not sure of is whether or not , and how much, electronic parts cleaner spray that i need to use and what to use it on. any ideas?
2000 c230 with 75K
"CHANGE" ...good change or bad change..Obama didn't say. benz rider Off-Topic 43 11-05-2008 10:04 PM
The "W" and the "S" next to the Gear Shift...(Auto Tranny) MLTHREEFIFTY R170 SLK-Class 10 03-27-2007 06:12 AM
w123 fuel leak in "hard" or "metal" line polychroma W123 E,CE,D,CD,TD,TE Class 1 02-02-2007 12:23 PM
Anyone have any experience with the "new" Michelin Pilot Sport All Season tires? Geoff R170 SLK-Class 5 09-18-2003 08:28 AM
