» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W202 C-Class
Old 08-24-2008, 12:53 PM   #11 (permalink)
Chadted's Avatar
Date registered: Mar 2008
Vehicle: 94 C280 140,000 miles
it get stuck mid way through the threads for the other piece....... goes in about... 1/4 inch
Chadted is offline   Reply With Quote
Old 08-25-2008, 06:40 AM   #12 (permalink)
liquidusculade's Avatar
Date registered: May 2008
Vehicle: 95 C220 (daily driver) 99 CLK430 (garage queen) 04 Volvo S60 (her's)
hmm, did you try forcing it past the threads? i cant see it getting stuck down in the tube but maybe it will. if it were me, i would try to get it past the threads and if it still gets stuck, then try forcing it back out to maybe sand off some of the metal. im not too sure what to tell you, i dont really remember having problems with mine except for getting the motor to work because it wasnt hooked up to my radio. i had an aftermarket head unit and had to wire that up to operate my antenna.
the antenna that was on my car was broken when i bought it. the previous owner drove it through a car wash with it up haha. i just recently fixed it after 2 years anyways, i had to remove some of the broken metal out of it too so i removed the entire unit and put my antenna in that way, i was not trying to stick it down through the outside of the car.
liquidusculade is offline   Reply With Quote
Old 08-25-2008, 03:09 PM   #13 (permalink)
Chadted's Avatar
all fixed now, i filed down the end of it and it goes up and down no problem...... thanks eveyone
Old 08-25-2008, 05:27 PM   #14 (permalink)
glad to hear it!
antenna mast rob76 W124 E,CE,D,TD Class 1 05-25-2009 06:10 PM
Does the Antenna Mast Always Come Up ... 94Wagenmeister W124 E,CE,D,TD Class 7 11-03-2006 01:55 PM
Antenna Mast peter811 W123 E,CE,D,CD,TD,TE Class 2 12-04-2005 01:37 PM
Antenna Mast josephanthony For Sale, Trade & Wanted Items 2 04-29-2005 05:37 PM
Antenna Mast garage bohemian W126 S,SE,SEC,SEL,SD,SDL Class 2 07-02-2003 02:03 AM
