what type of coolant do you use in your benz? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 08-12-2008, 10:24 AM Thread Starter
~BANNED~
benz rider's Avatar
Vehicle: 97'C280
MB recommends that we use their "special" formula coolant but I can't find it on the shelf. so I recently had to top it off with some Peak 50/50 pre-diluted.
did I do a bad thing?
what do you use?
benz rider is offline
post #2 of 5 (permalink) Old 08-12-2008, 10:44 AM
gauthier613's Avatar
Date registered: Jul 2007
Vehicle: 2000 C230 Mercedes Kompressor, 2004 Honda Civic, 1980 L48 Corvette
You have to use MB or Zerex G-05
Some things that can happen if you use the wrong stuff is rust and improper cooling and lubrication.
gauthier613 is offline
post #3 of 5 (permalink) Old 08-12-2008, 07:25 PM
redhope's Avatar
Date registered: Apr 2008
Vehicle: 190E-16v & C230
You're *suppose* to use the MB brand or the Zerex g-05, like Greg mentioned above. The Zerex is cheaper, and I've been told my countless MB folks that mercedes uses the same stuff as Zerex and slaps their label on it.
I did put Peak in my c230 recently, but I plan to replace it with the Zerex soon. Like Greg said too, it can tamper with your system very slightly. I've heard it'll wear out your hoses because it's an incorrect chemical. Things like that. I haven't noticed a temp issue with my car, but I rather be safe than sorry.
You can buy the Zerex at NAPA. You use to be able to get it at Autozone or Pepboys, but I couldn't find it. But NAPA definitely has it. Sorry for the babbling too!
Project: 1986 190E 2.3-16v Black
PO: 1998 C230 2.3 Imperial Red
Commuter: 2009 Toyota Corolla Sport
redhope is offline
post #4 of 5 (permalink) Old 08-12-2008, 07:54 PM
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
In the US, Valvoline makes the coolant for MBUSA to their specifications. While not molecule for molecule the same as Zerex G-05, the two fluids meet the same G-05 standard for alloy motors.
The Zerex in the gold jug is substantially cheaper than the white jug from the dealer, but you'd be hard pressed to say that one is better than the other.
MTI is offline
post #5 of 5 (permalink) Old 11-12-2008, 11:27 AM
Vehicle: 2011 C300; 1995 C220(sold); 1985 300D Turbo (sold)
This is kinds a stupid question, but when you add coolant, how high should you add? Most of cars I owned have a mark on the reservoir indicating the level of coolant should be. But I see no mark, nor did I find it mentioned in the manual. If there is a mark somehow I missed, where is it?
sagaliba is offline
    Coolant Color/type Binny W201 190-Class 12 11-09-2007 07:19 AM
    Type of Coolant dimon1980 W163 M-Class 1 11-29-2006 11:38 AM
    Engine Coolant Type DD Johnson W126 S,SE,SEC,SEL,SD,SDL Class 3 10-22-2006 02:35 PM
    coolant type/ differential type ladybee W126 S,SE,SEC,SEL,SD,SDL Class 3 02-25-2005 06:06 PM
    Coolant type Guest (MBNZ) W201 190-Class 3 11-22-2001 03:31 PM
