Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W202 C-Class
Old 07-21-2008, 05:30 PM   #1 (permalink)
lovemyc280's Avatar
Date registered: Oct 2003
Vehicle: 1994 c280
Chirping sound from vents
I'm hearing an on again, off again chirping sound from my A/C vents at mid level speeds. Seems to go away at high/low setting.
Any thoughts? Blower motor on the way out?
What am I hearing?
It's annoying.
lovemyc280 is offline   Reply With Quote
Old 07-21-2008, 06:41 PM   #2 (permalink)
cjshade's Avatar
Date registered: Nov 2007
Vehicle: 96' C220
Post Chirp Chirp
Does it sound like a bearing screaching or maybe a piece of debris? We had a funny noise like that for a while only on some speeds and found out a leaf got in there through the air intake. It finally worked its way out to a vent grate and we picked it outta there. How it got past the filter is a mystery...
Good Luck!
C as in 220
cjshade is offline   Reply With Quote
Old 07-21-2008, 08:11 PM   #3 (permalink)
lovemyc280's Avatar
Vehicle: 1994 c280
I originally thought that, and turned the fan full blast for a few minutes. When I allowed it to return to auto climate control (and thus a lower fan speed) the noise was gone. I figured I blew the debris off, but then it returned today.
It is a high pitched noise, like a cricket almost.
Old 07-21-2008, 08:33 PM   #4 (permalink)
MoLD`'s Avatar
Date registered: Jun 2008
Vehicle: white 97 c230
a/c belt? or the compressor is going?
97 c230 white
93k
20% tints
MoLD` is offline   Reply With Quote
Old 07-22-2008, 11:16 PM   #5 (permalink)
nankeochanh's Avatar
Date registered: Oct 2006
Vehicle: 95 C220
Send a message via MSN to nankeochanh
well i had the exact same problem and then my blower motor went. so if you blower motor goes then we know what the problem is. LOL. when you take it out you'll problem see that it's all rusted. well the bearings. yep then you'll need one for sure. hope that helps
nankeochanh is offline   Reply With Quote
Old 07-23-2008, 12:43 AM   #6 (permalink)
lovemyc280's Avatar
Vehicle: 1994 c280
Thank you. How do I access the blower motor?
Old 07-23-2008, 06:58 AM   #7 (permalink)
Date registered: Apr 2008
My c220 has a high pitch screeching noise from the vent when the temperature is really cold, and after I apply the brake. The noise is not from the brake as it continues to screech even after the car is completely stop and is idling. I can make the noise go away by turning the system on and off. This is the problem since when the car was new. Unfortunately, it happens only in real cold weather, and every time I took it to the dealer, the temperature has warmed up enough they could not hear it.
Now after so many years, it is still there, and I still have no idea what caused it.
sagaliba is offline   Reply With Quote
Old 07-23-2008, 09:13 AM   #8 (permalink)
jlomon's Avatar
Date registered: Dec 2006
Vehicle: 2000 E320 4Matic Wagon, 1994 C280
It is located in the same access area as your cabin filter and is very easy to remove. It is held in by torx-head screws, but I don't remember which size torx. When I had a similar situation with my C280, the noise was being caused by little leaves and pieces of debris that was caught in the fan/blower assembly.
jlomon is offline   Reply With Quote
Old 07-24-2008, 11:47 AM   #9 (permalink)
lovemyc280's Avatar
Vehicle: 1994 c280
That's easy enough, thanks. I am familiar with the removal of the cabin filter. So I'll just put a new one in and take a peak around while it's out. I'm sure it's easier than the throttle actuator I just replaced (Which actually wasn't hard either.)
Old 08-03-2008, 05:07 PM   #10 (permalink)
Vehicle: 1995 C280
Took my blower motor cover off.Sound goes away when i wiggle the wires or try to wiggle the blower motor itself.Sounds like a bearing going bad i guess
dn9979 is offline   Reply With Quote
Chirping Sound then Brake Screach after warmup Cewoz R/C107 SL/SLC Class 7 05-16-2008 02:21 PM
chirping sound DORIAN R129 SL Class 6 07-02-2007 11:44 PM
Chirping sound hsv5000 W163 M-Class 3 04-15-2007 08:10 PM
Chirping Sound S600 milbrath47 W140 S-Class 2 07-09-2006 05:33 PM
Chirping sound in a cold weather ? MikeH W163 M-Class 6 12-11-2002 07:13 PM
