Problems With 1997 C280 A/C and Climate Control - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-12-2008, 05:21 PM Thread Starter
bonawitz07's Avatar
Date registered: Jul 2008
Vehicle: 1997 C280
Question Problems With 1997 C280 A/C and Climate Control
Hello,
I have a 1997 mercedes c280 and I'm having some troubles with the A/c and climate control. When I turn the temperature to "Low" or 52 degrees which is the lowest temperature where you would expect the A/C to come on, warm air just comes out. I have tried recharging the system with the proper refridgerant but nothing changes. The A/C compressor does come on and runs so I don't think that's the problem. The other functions with the dashboard control unit work fine. Does anyone have any ideas on what's wrong or what I should do? Thank you.
bonawitz07 is offline
post #2 of 5 (permalink) Old 07-12-2008, 08:05 PM
bmeister's Avatar
Date registered: Oct 2007
Vehicle: 1998 c230 170K
Quoted: 9 Post(s)
Have you attempted the CCU diagnostic?
[QUOTE=bonawitz07;2966704]Hello,
I have a 1997 mercedes c280 and I'm having some troubles with the A/c and climate control. When I turn the temperature to "Low" or 52 degrees which is the lowest temperature where you would expect the A/C to come on, warm air just comes out. I have tried recharging the system with the proper refridgerant but nothing changes. The A/C compressor does come on and runs so I don't think that's the problem. The other functions with the dashboard control unit work fine. Does anyone have any ideas on what's wrong or what I should do? Thank you.[/QUOTE
Have you tried the CCU diagnostic procedure? If that checks out o.k. then you may want to put dye leak detector in to see if there is a leak in the system. You can purchase a inexpensive a/c guage at most parts stores to also check the high and low side operating pressures. B
bmeister is offline
post #3 of 5 (permalink) Old 07-18-2008, 03:31 PM
Date registered: Apr 2007
Ok, i have a similar issue. I know how to run the diagnostic test on the head unit, but don't know what the normal numbers should be?
tui0jst is offline
post #4 of 5 (permalink) Old 07-18-2008, 06:09 PM Thread Starter
bonawitz07's Avatar
Vehicle: 1997 C280
Me either, I can get the numbers but have no clue what they mean. Any help??
post #5 of 5 (permalink) Old 07-20-2008, 06:07 PM
~BANNED~
benz rider's Avatar
Vehicle: 97'C280
benz rider is offline
    help - 1997 e320 climate control ?? donaldgarzino W210 E-Class 5 04-29-2009 07:20 PM
    2000 C280 climate control GregZ W202 C-Class 2 04-22-2008 08:35 PM
    Climate control on 96 c280 CLASSW202 W202 C-Class 0 02-25-2008 10:26 AM
    For sale 1995 C280 Climate control Cataplas For Sale/Wanted/Trade/Giveaway 0 11-03-2006 03:08 PM
    96 C280 W202 Automated A/C Climate Control Problems Steve R. W163 M-Class 0 03-25-2001 04:25 PM
