» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W202 C-Class
Old 05-01-2008, 05:58 AM   #1 (permalink)
Date registered: May 2008
Post Hard Starting
My Benz C230 is having a problem when the engine is cool it start with one kick but when hot it give hard starting pls what could the possible cause thanks
suleiman sulkhan is offline   Reply With Quote
Old 05-01-2008, 10:29 PM   #2 (permalink)
cjshade's Avatar
Date registered: Nov 2007
Vehicle: 96' C220
Post Hard Starting
Could be the Crank Pos Sensor. They will usually shut the car down when they get hot and then not allow it to start until the engine cools down a bit. (May be on its way out) My other standard guess would be the Mass Air Flow Sensor. They will make your care exibit all kinds of crazy symtoms without throwing a code. BTDT
Good Luck!
C as in 220
cjshade is online now   Reply With Quote
Old 05-05-2008, 07:54 AM   #3 (permalink)
Post
So pls what do i do to correct this hard starting issue, this car C230 cover only 88884km and is still as good as new car of yesterday
Old 05-05-2008, 10:44 AM   #4 (permalink)
cjshade's Avatar
Vehicle: 96' C220
Post CPS
Your problem will most likely go away if you replace the Crank Position Sensor. I just learned this check the other day on this forum to confirm it's the CPS. (I tried this on mine and hardly saw a differance) The next time it fails on you: see if the Tach needle moves when your cranking the car. If you get no movement like you get when you start the car from cold, it's the CPS that has failed. Very common problem in these cars and not too expensive to fix. If you are a DIYer you can do it yourself. Otherwise have a Mechanic replace it for you. I did a thread starting 11-27-07 (search by date) on this when we replaced ours. Some very nice people sent pictures to make it easier.
The distance one of theses cars has traveled does not seem to matter with a CPS failure, newer models have this problem too. It's a weak Bosch part apparently. The Camshaft Pos. Sensor is similar but does not seem to go out near as often.
Does the car start after cranking a while, or does it have to cool down before it will start? If your Tach needle bounces a little while cranking and it eventually starts: You may have a MAF going out, or a dirty Throttle Body. These can be cleaned, The MAF is easy to replace yourself. If you need one of those, I suggest you buy the (insert part) online it is much cheaper than buying the housing part with it. There's lots of threads to search on this forum to help you with that too.
Good Luck!
C as in 220
Old 05-07-2008, 06:44 AM   #5 (permalink)
thanks alot, but you see i dont even know where the CPS is in the car so also the MAF kindly give me full description on how to get to those sensor in the car
thanks and God bess you
Old 05-08-2008, 10:49 AM   #6 (permalink)
cjshade's Avatar
Vehicle: 96' C220
Post CPS replacement instructions
I will revieve the old thread for you. Watch for it somewhere close to the top of the forum. It is titled is something like "Crankshaft Position Sensor Replacement".
Good Luck!
C as in 220
Old 05-23-2008, 08:16 PM   #7 (permalink)
Date registered: Sep 2007
if you have to buy an mass air flow sensor try this place eBay Store - autopartpro: Oxygen O2 Sensors, Honda, Toyota
92.00 with shipping and was not just an insert
all you will neeed to replace it is a screw driver
glenn1 is offline   Reply With Quote
Hard Starting HardstartingVito V-Class 17 08-06-2007 12:54 AM
Hard Starting dahappybanana W124 E,CE,D,TD Class 21 06-11-2007 12:53 PM
Hard Starting Gav71 W124 E,CE,D,TD Class 4 08-01-2005 04:03 PM
Hard starting AnE2pleaz W124 E,CE,D,TD Class 3 08-29-2004 01:15 PM
hard starting saporter W201 190E, D-Class 8 02-17-2004 05:50 PM
