Definatly the belt if it's not recent. The bearing in the Idler Pully can be pressed out and replaced, or you can buy the Pulley with Bearing pretty cheap.
The 90 degree hose between the Thermostat housing and the Water Pump. The Thermostat housing if it's old. Replace the rest of your hoses and clamps if they are old as well. Use MB or Zerex 05 Coolant and Distilled water. Yes, it's important to get the right coolant.
As far as special tools... I think it was a 5mm Allen that you need to remove the Fan Clutch. Unless you have a very short 90 degree Allen your hatin' life. I just took a Allen wrench an ground it down on my grinder till the short end fit.
Valve Cover Gasket... You might wat to change out your Plugs and Wires. I put the Bosch 4 ways in mine and have been very happy with the additional power and gas smilage.
If you've done a Head Gasket, this will be a piece of cake for you. Take your time and enjoy.
Good Luck!
C as in 220
