Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W202 C-Class
Old 04-20-2008, 04:47 PM   #1 (permalink)
Date registered: Apr 2008
Vehicle: C200
C200 Car Battery
Hi
i have just bought a 1995 C200 Auto Petrol and I noticed today that the battery is only rated at 50ah. When in halfords, they told me the car should have a 75ah battery which is why the engine turns over sluggishly when starter motor is operated.
is this true and in your opinion, would it be worth the expense of buying a higher power battery? Or are they just trying to make a sale.
Many thanks
Paul
rarefaction is offline   Reply With Quote
Old 04-21-2008, 07:34 AM   #2 (permalink)
Derek Lecours's Avatar
Date registered: Dec 2006
Vehicle: B 200 & Audi A6
Even if the battery has a lower rating in "Ah", it should turn the starter at a normal speed. The smaller battery would just turn the starter for a shorter time before slowing down.
ie: the 50 ah would crank for 2 minutes and the 75 ah would crank for 3 minutes before running out of sufficient strength.
There are battery testers that can tell you the condition of your battery.
If you have extremely cold weather, then a strong healthy battery is the way to go.
Cheers, Derek
Old 04-21-2008, 08:01 AM   #3 (permalink)
Vehicle: C200
Thanks
Very many thanks for that information, very useful. I will now just get my battery tested and if it proves to be in good condition, will save my money and stick with that.
Cheers,
Paul
Old 04-22-2008, 07:32 AM   #4 (permalink)
Vehicle: C200
Update
Hi again.
I called at local Kwik Fit last night for a free battery test. The lad did the test and showed me that their tester showed amber, with no ignition volts at 12.5 and cranking voltage at 9.3.
He then advised as Halfords did that the 50amp battery seemed too small for the car. He did say that their books suggest the same size battery but that every Merc he'd had in was fitted with a much bigger battery.
Any advice, cheers,
Paul
Old 04-22-2008, 09:00 AM   #5 (permalink)
Date registered: Aug 2005
Vehicle: 1999 Euro C280 Sport
50 Ah is to small for the car you should have 75 or more Ah. Mine is idle 13.5 v and without ignition 12.6 v.
Eddie
Curacao is offline   Reply With Quote
Old 04-22-2008, 09:05 AM   #6 (permalink)
Vehicle: C200
Thanks
Thanks for the quick reply Eddie. Will get the 75amp Heavy Duty one from Halfords as they have it for £74.00
Paul
Old 04-22-2008, 09:07 AM   #7 (permalink)
Date registered: Mar 2008
Vehicle: '94 C280 US Spec
I agree, my old car was a 2.0i and a 70+Ah was suitable.
For comparison, my C280 has always had a 100Ah.
Fusion.C280 is offline   Reply With Quote
Old 04-23-2008, 04:48 PM   #8 (permalink)
Vehicle: C200
Just fitted the heavy duty 75a battery as advised by you guys and 100% improvement. Money well spent. many thanks for your help.
Paul
Old 04-24-2008, 08:35 AM   #9 (permalink)
If you mean the it's now turning over quicker(100% improvement), then the old battery was dying and the test should have shown that.
The bigger battery is the way to go. Derek
C200 Car Battery rarefaction W204 C-Class 1 04-21-2008 10:58 PM
Difference C200 Evolution Coupe\C200 Sports Coupe kevinblack W203 C-Class 0 07-14-2007 04:33 AM
Is 2001 C200 Komp a fast car? yazan Yared W203 C-Class 2 01-18-2007 03:01 PM
C200 Show car heckflosse_uk General Mercedes-Benz 3 12-20-2005 03:50 AM
Car doesn't start, battery??? Mouramen W201 190E, D-Class 6 12-09-2005 08:48 PM
