Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W202 C-Class
Old 03-31-2008, 09:42 AM   #1 (permalink)
Raxhi's Avatar
Date registered: Jan 2006
Vehicle: 1988 260E (Now my brother's), 1994 C280
Clanking Noise on 94 C280
This is kind of freaking me out. Every morning (or after the car sits for at least 2 hrs) when I start driving the car this happens.
1. Depress brake pedal and shift in Reverse (coming out of the driveway)
2. The second time I press the brakes, there is a "CLANG" (read metallic noise) coming from what seems is the front brakes
3. Depress brake pedal and Shift into Drive. Start moving forward
4. Next time I press the brakes "CLANG" there is the noise again.
The noise will happen only once in each direction, reverse and drive, or the otherway around if I start up on Drive and then switch to reverse.
Recent work on the car includes
Front Rotors (Brembo replacements)
Front brake pads (Akebone Euroceramic)
Bilstein HD shocks all around
Swaybar Bushings
My mechanic said it cannot be the brakes as they work after with no problem, I have not had the chance to leave the car there so he can test it.
Thanks in advance
Raxhi
Raxhi is offline   Reply With Quote
'95 E300, engine clanking noise when warm elefantrider W124 E,CE,D,TD Class 4 12-31-2007 02:28 PM
clanking / knocking noise orangebang49 The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 09-28-2006 06:01 AM
Clanking noise from rear of 300TE: What's the source? ron in sc W124 E,CE,D,TD Class 2 01-22-2006 12:32 PM
04 ml500 clanking noise pointman W163 M-Class 9 03-25-2005 11:43 AM
Clanking noise SteveL R170 SLK Class 3 03-22-2001 07:23 AM
