Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W202 C-Class
Old 03-17-2008, 11:44 AM   #1 (permalink)
Date registered: Mar 2008
Strange noise from the right back tail light
Hi there -
I recently bought a 1995 C280 - my first benz, and have noticed that after I start my car I usually can hear this reoccurring noise from the back right hand side of the car. It sounds like a motor trying to do something over and over again. It sounds similar to the sound of the antenna going up or the power door locks working. I went back and opened the trunk while this was happening and located the sound, it's coming from right around the area of the rear light on the right hand side. Does anyone have any idea what this is and how I can fix it? It's just annoying and I'm not sure what it is.
It eventually stops and it doesn't always happen. I have no idea what it is. Thanks.
drshabazz is offline   Reply With Quote
Old 03-17-2008, 01:09 PM   #2 (permalink)
~BANNED~
benz rider's Avatar
Vehicle: 97'C280
could be a vacuum pump that unlocks the trunk and doors. I was told that it is located back there. maybe you have a bad relay switch in there or something.
benz rider is offline   Reply With Quote
Old 03-18-2008, 02:55 PM   #3 (permalink)
torrem3's Avatar
Date registered: Oct 2006
Vehicle: 95 C280 Silver Metallic(champagne), 89 300E Onyx Mettallic<< All Options both w/car phones
I thought it was the secondary air/ vacuum pump. When it makes a noise like that it usually is a tell tale sign of a leak in the system some where
torrem3 is offline   Reply With Quote
Old 03-18-2008, 03:16 PM   #4 (permalink)
any idea if this is a simple DIY type of job or is it more complex to fix what the likely problem is? any idea on the price of said fix if I do take it to a mechanic to get it fixed?
Old 03-19-2008, 10:34 AM   #5 (permalink)
torrem3's Avatar
I actually just finished replacing my Combination stalk on my car so the Pump will be the next thing for me . I seems like a simple DIY just ardous because I believe you are going to be testing different lines to check for a vacuum leak. I will be attempting it this weekend. Before that I have to get the Vacuum line diagram from the dealer so I know where the lines run.
Old 03-20-2008, 12:22 PM   #6 (permalink)
torrem3's Avatar
I now have the diagram from the dealer and well it doesn't look good. It looks like it can be the airconditioning system Central locking system or the Rear Head rest adjustment. I will tackle the Doors and Rear head rest first but it may the dreadful a/c system
Old 06-03-2008, 11:55 AM   #7 (permalink)
Date registered: Oct 2007
Vehicle: 1995 C280
Hi Torrem3,
Can you please post the diagram up when you get a chance. I think this will help me with my vacuum leak problem
junklar is offline   Reply With Quote
Old 06-03-2008, 08:36 PM   #8 (permalink)
torrem3's Avatar
Originally Posted by junklar View Post
Hi Torrem3,
Take a look at the Eureka Thread I should have something up between tonight and tommorow afternoon.
Strange Brakes and strange noise from car micosavo W210 E-Class 9 06-18-2007 05:55 AM
Strange tail light FreQ W124 E,CE,D,TD Class 10 09-07-2006 06:07 AM
strange noise black benz W201 190E, D-Class 4 08-17-2005 02:58 PM
strange noise belosch G-Class 14 03-01-2005 06:06 PM
anyone changed their old tail light to new style tail light? Ken R170 SLK Class 2 04-24-2002 05:03 AM
