Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W202 C-Class
Old 03-17-2008, 11:14 AM   #1 (permalink)
Date registered: Nov 2007
will these rims fit?
i have a totally stock W202 c280 from 95. then i've seen some OEM mercedes-benz rims. the only size i can get is 8,5 J x 18 ET 43.
will these rims fit my car without any problems or mods? and what size of tires do i need?
hashim_Dad is offline   Reply With Quote
Old 03-18-2008, 02:22 AM   #2 (permalink)
Vehicle: 1996 C220
The ET is wrong for the W202, you need a 25 for 18x8,5 rims.
This is the link I use to help me find the other rims that fit the W202.
Mercedes AMG BMW new used & refurbished alloy wheels & tyres, UK wheel alloys
The relevant portion for us...
C Class (W/S202)
15x6.5 37 195/65R15 Mercedes-Benz
15x7 37 205/60R15 Mercedes-Benz
16x7 37 205/55R16 Mercedes-Benz
16x7 37 205/55R16 16x8 36 225/50R16 Mercedes-Benz
17x7.5 37 225/45R17 Mercedes-Benz/AMG
17x7.5 35 225/45R17 Mercedes-Benz/AMG
17x7.5 37 225/45R17 17x8.5 30 245/40R17 Mercedes-Benz/AMG
17x7.5 35 225/45R17 17x8.5 30 245/40R17 AMG
17x7.5 37 225/45R17 17x8.5 34 245/40R17 AMG
17x8 30 225/45R17 17x10 27 245/40R17 Carlsson
18x7.5 37 225/40R18 AMG
18x7.5 37 225/40R18 18x8.5 30 255/35R18 AMG
18x7.5 37 225/40R18 18x8.5 34 255/35R18 AMG
18x8 31 225/40R18 AMG
18x8 31 225/40R18 18x9 35 255/35R18 AMG
18x8 35 225/40R18 18x10 27 255/35R18 Carlsson
18x8 35 225/40R18 18x9 28/35 255/35R18 Carlsson
18x8.5 25 225/40R18 AMG
18x8.5 25 225/40R18 18x10 25 255/35R18 AMG
18x8.5 35 225/40R18 Carlsson
18x8.5 35 225/40R18 18x8.5 35 255/35R18 Carlsson
18x8.5 35 225/40R18 18x10 30 255/35R18 Carlsson
Two tire sizes on a line are front and back in staggered setups. The last three on the list with 35 ETs have a bunch of footnotes attached that state you will need to modify the wheel openings to fit.
I also use the entire chart to identify the other platforms that used these rims to help locate them in the for sale sections.
Good luck and good hunting!
jonRobbinSS is offline   Reply With Quote
Old 03-18-2008, 04:00 AM   #3 (permalink)
thank you... but i have one question. if i buy 4 wheel with the size 8,5 x 18. will i be able to mount 225/40-18 in front and 255/35-18 in the back?
Old 03-18-2008, 04:01 AM   #4 (permalink)
and i think that the wheels with ET35 WILL fit because on my last w202 i was rolling on wheels with ET37 and there was a lot of place left
Old 03-18-2008, 10:48 AM   #5 (permalink)
Vehicle: 1996 C220
1) 255 is a doable width on an 8.5 in rim. So it should work..
2) I don't have any first hand experience with the larger end of the wheel fitment chart, so perhaps you are right but were your last w202 rims 18x8.5? If you notice all the sizes below about 18x7.5 use 37.
As the width of the rim increases the ET number also needs to change. If your old rims were 7.5 with 37ET and you go to a 8.5 with 37ET, you have just pushed that wheel out about 1/2 inch, which could be a problem with fender clearance somewhere during the suspension travel. The switch to a 25ET on the 8.5 rim pulls the wheel back into the fender 12mm or .47 inch keeping the face of the wheel in almost the same place.
If you decide to try the 8.5 with 37ET let us know how it works.
Old 03-18-2008, 01:12 PM   #6 (permalink)
i just think i'm gonna try out with the 8,5 x 18 with ET 35. but in the front i dont know if the 255 tire will fit because if i put on 225 the rims will be a bit longer out than the tire and it will be scratched easily
will these rims fit? asadaq786 W163 M-Class 0 01-15-2007 06:35 AM
Will these rims fit? flightSLK R170 SLK Class 15 10-05-2006 03:59 AM
will these new rims fit? ButteryBenz W201 190E, D-Class 5 01-14-2006 02:59 AM
Will these rims fit?? Help skratch23 R170 SLK Class 4 07-16-2004 03:25 PM
WILL RIMS THAT FIT W140 FIT A W126 BODY STYLE Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 03-09-2002 06:25 PM
