Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W202 C-Class
Old 03-08-2008, 10:43 PM   #1 (permalink)
rudedude's Avatar
Date registered: Jul 2005
Vehicle: ML320,C230, F250, Bayliner, Mountain Bike, Fleetwood Motorhome etc...
amp and 10" installed
Well today I installed a 1000 watt amp and 2 10" subs in my C230. I got lucky because the power switch wire to my Alpine CD changer worked on the amp too. I removed the old stock subs and wired everything in. The 10" subs are mounted in a sub box. I still have plenty of trunk space. What a difference. Even the 4 door speakers sound good now because the sterio is using less power. The only problem now is sometimes tha CD changer skips because of certain bass frequencies. Any idea what I can do to isolate the CD changer so it won't skip?
True success is being the master of your own time.
rudedude is offline   Reply With Quote
Old 11-08-2008, 12:50 AM   #2 (permalink)
Date registered: Mar 2008
you could try wrapping it or enveloping it in a foam of some sort, similar to the vacuum or aircontrol unit in the rear right quarter behind the carpet, but id say the sub vibrations are travelling to the mechanism of the cd player.. btw, is ur sub rated at 1kW RMS or peak, and what rating are the subs, and brand names, thx..
J-Dogg69 is offline   Reply With Quote
"Yakuza" Sato's AMG Mercedes from "Black Rain" (starring Michael Douglas&Andy Garcia) JJB236 W124 E,CE,D,TD Class 20 08-06-2007 09:12 AM
AMG "Special Edition" plaque installed (Pics) omeyhomey W210 E50 AMG, E55 AMG 6 01-23-2007 10:11 PM
Pics of Ebay "AMG" Projector Fogs Installed ClkE W208 CLK Class 2 08-11-2006 03:36 PM
European Navigation & TV Tuner Installed in my e class & I LOVE IT !!! hus Audio & Telematics Forum 5 09-09-2003 01:54 PM
500 SEC "brake bushings" & "castor supports" Graham W126 S,SE,SEC,SEL,SD,SDL Class 5 08-26-2003 01:14 PM
