windshield washer blade stuck in the middle - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 02-09-2008, 10:09 PM Thread Starter
alexus.one's Avatar
Date registered: Jun 2007
Vehicle: C280 '97, SLK55 BRABUS AMG '05
Quoted: 2 Post(s)
Question windshield washer blade stuck in the middle
Hey all i have problem with windshield washer blade (or whatever you call that thing that whipes off rain, wiper?) Basicaly the wiper goes to the middle of windshield then its stops for 1 sec and then continues very slowly till the end of the glass and then goes back the same way to the middle gets umm stoped by something and baraly returns to initial position. Same happens on all speeds.
Does any one have any idea what can cause it? And how can I fix that?
Thanks!
alexus.one is offline
post #2 of 10 (permalink) Old 02-09-2008, 11:21 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 666 Post(s)
Could be a bad wiper transmission.
GeeS is offline
post #3 of 10 (permalink) Old 02-09-2008, 11:26 PM Thread Starter
alexus.one's Avatar
Quoted: 2 Post(s)
um well, how can i chek is that is the case? and how can i get to the motor?
I was trying to get there but there are some locks (plastic clisp) that are too close to some fluid containers and some compartment walls.. so i cant get to the motor...
post #4 of 10 (permalink) Old 02-10-2008, 08:38 AM
Project6's Avatar
Date registered: Dec 2004
That happened to me a while back, and I found a post somewhere that tells you how to fix it The fix was just to lube the piston, and it's pretty easy to do. Takes a bout 15 min. here's the link and hope it helps you out. 202Tech - Hesitating Wiper Fix
Good luck
P.S after I did mine it works like brand new.
160k and counting
PROJECT6
www.stepintomyshoes.wordpress.com
Project6 is offline
post #5 of 10 (permalink) Old 02-10-2008, 11:04 AM Thread Starter
alexus.one's Avatar
Quoted: 2 Post(s)
will do what they told there, will post back result!
Thanks bro
post #6 of 10 (permalink) Old 02-10-2008, 11:18 AM
Date registered: Mar 2007
Quoted: 2 Post(s)
Jep mostly it just needs some grease. Had the same problem about a year ago.
Be carefull not to put too much grease on it because it will get on the windscreen and blur your vision.
Jomzo is offline
post #7 of 10 (permalink) Old 02-10-2008, 03:34 PM Thread Starter
alexus.one's Avatar
Quoted: 2 Post(s)
damn, i wasnt able to remove that rectangular cover... maybe its because temperature outsite droped by like 30 withinh half an hour and i just could sit ouside
will try again tomorrow
post #8 of 10 (permalink) Old 02-19-2008, 04:19 PM
jim230c's Avatar
Vehicle: 1998 C230 Silver grey leather 50k / 2002 BMW 325i silver black leather 70k
Had the same problem. There was a post abou this a few weeks ago and it said to take the 2 covers off the wiper arm and spray lithium grease on the mechanism. I could not the large cover off but was able to spray grease in under the arm between the arm and windshield. It worked great. If I find the post I will direct you to it.
Jim
jim230c is offline
post #9 of 10 (permalink) Old 02-19-2008, 04:20 PM
jim230c's Avatar
I see in an earlier reply someone has already sent you the link....
Jim
jim230c is offline
post #10 of 10 (permalink) Old 02-19-2008, 08:40 PM Thread Starter
alexus.one's Avatar
Quoted: 2 Post(s)
Ops I forgot to post reply
I was trying to remove either cover and no luck. it just doesnt go off. I think there is sone sort of lock that is not described, or I am such a dummy that cant get it right
Can some one give me more detailed guidence on how to remove the covers off?
Thanks!
    Stuck in middle of shock installatin - please help! athensaaron W123 E,CE,D,CD,TD,TE Class 4 01-04-2008 12:46 PM
    wiper blade scratching up the windshield..?? ProV1x W210 E-Class 6 10-15-2007 04:23 PM
    Windshield wiper blade: wrong position. Makarov1 W202 C-Class 3 01-05-2007 06:59 PM
    Help! Cant get windshield wiper blade down on E300 86 john1985 General Mercedes-Benz 1 12-17-2003 08:13 PM
    Need windshield wiper blade recommendation... Brian R170 SLK-Class 8 06-18-2001 05:09 PM
