I was told that my car needs brake fluid what exactly that means i'm not sure. Do i need to bleed the old fluid or do i just add additional fluid? When I apply my brakes they start squeeking towards the end. Also when I put my Emergency brake on after i park it seems to make a creaking sound. When i went to the a mechanic they said they were fine. I believe my pads & rotors/discs are not older than 2 years. Could this be the brake fluid? and/or hyrdaulic fluid? What is the difference?
On a 2002 car, it would be unusual to have fluid loss problems
Fluid should be flushed out with new fluid every 2 yrs ideally - easy job
#Suck out as much old fluid out of the container as possible(don't depress the pedal at this stage)-almost fill with new fluid
#Start with longest brake line and bleed until new fluid comes out.
#Bleed other 3 lines finishing with shortest (keep an eye on fluid level)
As far as current level is concerned, check the see thru' container - also a light will come on if you are really low.
Mileage over the last 2 yrs is more imp. than time -if a reputable mechanic has checked them (also, light will come on if pads are low) it may just be a lack of 'anti sieze' type lube where the pads fit into the caliper.
your discs may need de glazing as a last resort.- may also be non std pads
Also important is replacement of coolant every 3 yrs - v.expensive consequences of neglecting this.
About flushing out the brake fluid...I suppose they don't do this with the A service? I have a mityvac do you think it is easy as a diy ...I'm not sure how to go about bleeding the brake lines or really where they are located. I guess that must mean I should go to a professional. If I am not going to the MB dealership should I buy the fluid online and give to the mechanic to do the labor? or should they be able to provide proper MB fluid ?
#Jack vehicle up to get access behind wheels (removing wheel makes it easy) - ensure safely on jack stands
#suck out all fluid from master cylinder under bonnet with a bit of old tube - be careful not to spill any on paint
#fill with new dot 4 or 5 brake fluid of your choice (MB fluid not vital here)
#install wife in drivers seat and tell her not to jump around too much
#starting at furthest wheel from master cylinder, loosen the drain nipple on the caliper and fit tube over nipple to catch old fluid into a container
#tell wife to press down on pedal and hold down till you lock nipple - tell her to release it - then press down again, open nipple and lock it - repeat UP/DOWN until new colour fluid appears - lock nipple and repeat with other 3
TRAP - watch level of fluid in master cylinder or you'll get air in the lines and have to waste more good fluid getting it out - check after each wheel - twice on the first
You may wish to consider buying a power bleeder. Flooring the brake pedal moves the master cylinder piston beyond it's normal travel. This accelerates the wear on the master cylinder's piston seal.
This also makes it a one-man job. Fill the bleeder, pump it up, and crack open the bleeder nipples as described earlier. Also, with one of these, the MC won't run dry.
694.8K members
