» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W202 C-Class
Old 11-19-2007, 02:02 PM   #1 (permalink)
nickCR's Avatar
Date registered: Jul 2005
Vehicle: 1996 MB C280
Transmission Slips in C280
Hopefully someone can help me with my question. I have had my car for a week now. When I drive very relaxed (gradualy increase presure on gas, gradually decrease), the shifting and behaviour of the transmission is perfect is "most" conditions.
When I step on it, once the car reaches about 3,000 RPM it suddenly starts to rev up to 4,000 RPM, this is combined by a loss of power to the wheels (basically I feel the momentum of the car suddenly change when I hit this spot).
This problem also happen when trying to go up a hill at slow speeds but occurs lower in the RPMs. Also extra weight contirbutes to the car doing this.
Also when I have the car floored (like when getting on the highway) the change between 2nd and 3rd can lag, it dis-engages thinks for a second or two then goes into gear, other times it makes the shift very quick but hard and other times it's normal.
So i'm kind of confused since it's really not giving any consistant results. Any ideas?
I am taking it to Bosch tomorrow to have them look it over and probably change the fluid but I was hoping someone could comment on this so I could possibly give them a starting point.
The car was sitting for about 2 months.
~ Nick
Costa Rica
1996 Mercedes Benz C280
1988 Mercedes Benz 300E (SOLD)
My site TicoVista for costa rica real estate and more.
nickCR is offline   Reply With Quote
Old 11-19-2007, 11:51 PM   #2 (permalink)
Date registered: Nov 2007
Vehicle: C200 - 1995
me2..i have the same problem
My c200 1995; have problem in shifting from 2nd to the 3rd. the problem is that when it shifts from 2nd to 3rd the gear seems to disengage ( as gear in N position) and engage again. when I am going slow; you will not notice the gear disengagement and engagment in shifting up from 2-3 gear. But when I kick down and rpm reach over 4000rpm on the 2nd gear- almost before the shifting up happens to the 3rd gear; gear get disengage (as gear in N position) then RPM reash over 5500 for 2sec then shiftup to the 3rd gear.
any help is so much appreciated.
falsorakjy is offline   Reply With Quote
Old 11-20-2007, 10:51 AM   #3 (permalink)
nickCR's Avatar
Bosch checked the car. From the road test the head mechanic said that the transmission is not acting correctly at all and will need the plates replaced. There are people locally that will do this for like $1000, so once that happen all should be a-ok with my car. I'll find out for sure later today as they are going to take the car to a transmission specialist.
Old 11-27-2007, 06:53 AM   #4 (permalink)
nickCR's Avatar
UPDATE: RESOLVED
I have excellent news to bring back to you all! The transmission after being thoroughly checked by Bosch was found to be low on oil and required some slight adjusting. So $100 for that and a full inspection (since it was a new car to me). I got the car back in perfect condition and runs like a dream!
I'm extremely pleased with the response time, the acceleration and handeling on this car. The C280 is deffinetly no disappointment and i'm very happy now with my purchase.
Old 03-12-2008, 02:32 AM   #5 (permalink)
umfetu's Avatar
Date registered: Jan 2008
Vehicle: Mercedes Benz C280 1995
I am so glad to hear that because my C280 is doing the exact same thing. I was worried that it would be a clutch inside the trany. Do you know what adjustments they made to the car?
umfetu is offline   Reply With Quote
280 se transmission slips in park oceaneer W116 S, SE, SEL, SD Class 4 03-05-2006 08:53 AM
98 C280 Automatic Transmission kxmills W202 C-Class 2 12-28-2005 08:55 PM
Transmission slips and jumps out of gear when hot... Tranny svc. done - any ideas for fix? GermanCarNut W124 E,CE,D,TD Class 2 06-06-2005 07:55 PM
Transmission problem.. slips Buzzbomb W201 190E, D-Class 1 11-16-2004 06:28 AM
C280 transmission fluid ilong_99 W202 C36 AMG, C43 AMG 0 09-12-2003 06:24 AM
