1996 C220 - No heat - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-30-2007, 11:36 AM Thread Starter
Date registered: Oct 2007
1996 C220 - No heat
Hi!
I am having a weird problem with my 1996 C220 where my 'heat' is blowing cold air unless I set my temperature control to 'HI' whereas I get heat. I had initially thought it was my heater core, but since I do get heat on the 'HI' setting, I guess that would rule that out. I am thinking it could by my 'ACC Dual Valve'
Auto Parts Warehouse Product Catalog - 1996 Mercedes Benz C220 ACC Dual Valve
located under the hood, under the plastic compartment in front of the passenger side, but I want to be sure before shelling out the money for a new one.
I also have another problem which I think is related...or causing this one...but can't be sure. I often hear the vacuum pump 'whirring' in the trunk of the car and I believe that it controls the servos of the climate control. If this is the case, then I am thinking I might need a new climate control unit being that it's not properly controlling the servos and thus, not getting heat until (for some reason) it's put on HI.
Any help is greatly appreciated!
dj_pi is offline
post #2 of 4 (permalink) Old 10-30-2007, 05:07 PM
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Quoted: 8 Post(s)
Off you go to W202 Non-AMG Section
Welcome to the Board!
-JOE55
JOE55 is offline
post #3 of 4 (permalink) Old 12-05-2007, 08:19 PM
bmeister's Avatar
Vehicle: 1998 c230 170K
Quoted: 9 Post(s)
Sounds like duovalve and possibly aux valve
Originally Posted by dj_pi View Post
Hi!
This past weekend I replaced my duovalve and auxillary pump, my douvalve was making the ominous thumpety thump under the dash for quite some time and finally had a window of time to address both my coolant change and quirky noise problem when the heat was on.
(yes I did change out the thermostat to and did a flush since it was undergoing a bypass operation) . There have been a few posts on how to rebuild the duovalve, personally my time is worth more, I'll leave that choice up to you. What happens to the pistons inside of the valve is that they can stick after years of use as well as the internal rubber parts wear not making a good seal, also the solenoids can go bad.
The auxillary pump was changed as a preventative measure since I really have no idea how old it was. Vehicle had about 58000 miles on it when purchased used, now has 92000.
I doubt your climate control is bust unless you are having both heating and a/c issues. It would be good measure to look under the dash and listen for any hissing from broken, loose, or disconnected vac lines.
The duovalve is a real tricky one to do on the c230 unless you want to yank a bunch of stuff out of the way, big hands are not helpfull for this particular job. If you can hire someone with small hands I am sure they would not get as sore as I did.
One of the signs you can look for to confirm the problem would be to open the hood while the heater is on (in your case full blast) and feel the two cylinders of the valve for a tapping on both sides, mine only did it on one side and actually made the lower radiator hose do a bouncing movement like a dangling sausage.
bmeister is offline
post #4 of 4 (permalink) Old 06-11-2012, 09:13 AM
Date registered: May 2012
Vehicle: 2000 Mercedes Benz C230 Kpmpressor, 110,000 miles
Hi, my car is having the same bouncing movement on the driverside(left) radiator and when I unplug the two cylinders of the valve the heat is on. Does this mean I need to change the valve with two cylinders?
daolincheng is offline
    ac charging for 1996 Mercedes C220 mikestutts89 W202 C-Class 2 07-22-2005 05:47 PM
    "For Sale" C220 (1996) luxboy General Mercedes-Benz 3 07-29-2004 12:17 PM
    how much can i sell my 1996 C220 (130000K)? luxboy General Mercedes-Benz 5 07-29-2004 11:52 AM
    1996 C220 dub27 W203 C-Class 0 11-07-2002 01:42 PM
    1996 C220 Guest (MBNZ) W202 C-Class 1 03-19-2002 05:22 PM
