Changing Spark Plugs - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 08-14-2007, 07:20 AM Thread Starter
Date registered: Aug 2007
Where are the spark plugs and ignition coil found on my 1994 C280? My car sounds like it is miss firing and has no power. Please help.
Vininha is offline
post #2 of 6 (permalink) Old 08-14-2007, 08:39 AM
Date registered: Aug 2005
Vehicle: 2003 S430 Sport Edition
When you change your spark plug replace also the spark plug cables. Get original parts.
Eddie
Curacao is offline
post #3 of 6 (permalink) Old 08-14-2007, 09:10 AM
jlomon's Avatar
Date registered: Dec 2006
Vehicle: 2013 VW Golf Sportwagen TDI, 2011 Mazda 2, 2000 E320 4Matic Wagon (retired),1994 C280 (retired)
Your spark plugs and ignition coils (there are three of them) are all located under the long silver panel in the centre of your valve cover. I think it is held in by either 4 or 6 allen-head screws. You'll have to remove the black plastic intake crossover pipe (connects the air filter to the intake manifold) in order to get access.
Each coil fires two spark plugs. There is a spark plug under each coil and then there is one under each plug wire, for a total of 6. As Curacao said, replace your plug wires while you're in there. There are only 3 plug wires, but there are also 3 coil end connectors that connect each plug to the coil.
jlomon is offline
post #4 of 6 (permalink) Old 08-14-2007, 06:01 PM
Date registered: Mar 2004
Vehicle: Amethyst 2001 C320
Sounds like you're having a wiring harness problem, and unfortunately replacing the spark plug wires won't fix that. Check this thread for more info: http://www.benzworld.org/forums/w202...g-harness.html
n0alpha is offline
post #5 of 6 (permalink) Old 08-15-2007, 07:16 AM
jlomon's Avatar
Actually, on an M104, the very first thing you should check for missing/rough running are the plug-end connectors between the 3 coils and the spark plugs under them. They're a couple bucks a piece, and a common cause of minor idle problems. Major rough running problems are likely to be a failed coil, which is also a simple (and relatively inexpensive) thing to deal with.
It is completely possible that it could be the wiring harness, I'm not discounting that. But there are much easier things to eliminate first, from a diagnostic perspective. The OP didn't say if he had his CEL on or not. He should definitely try to pull codes to see if there are error codes related to a specific cylinder or cylinders, and go from there.
jlomon is offline
post #6 of 6 (permalink) Old 05-03-2011, 02:47 AM
BenzHell's Avatar
Date registered: Feb 2009
Vehicle: 1994 C280 Sport Gunmetal Grey FULLY CUSTOMIZED
Question
Hello,
I am in the process of changing the plugs. Question How do I know if the wires,coils,black tube between coil and spark plugs are bad?
Any help will be greatly appreciated
BenzHell is offline
    Changing spark plugs GW216 W210 E-Class 3 06-21-2006 08:28 PM
    changing my spark plugs ML320 Transmission W163 M-Class 6 11-14-2005 01:28 PM
    Help! Changing Spark Plugs mischief W163 M-Class 14 10-20-2003 10:18 AM
    Changing Spark Plugs mischief W163 M-Class 9 10-09-2003 08:37 PM
    Changing Spark Plugs sstarley R170 SLK-Class 1 04-19-2003 08:02 AM
