c220 fuel leak, PLEASE HELP! - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 07-22-2007, 06:30 PM Thread Starter
Date registered: Jul 2006
I have a 1996 C-220 and I noticed a fuel leak about a week ago dripping out from near under the differential so I removed the right rear tire to trace where it was coming from...... I traced it to a rubber hose leading up to some sort of box (looks like an air-intake box) around the fuel filler neck.... I don't think this hose is the main fuel line, but then I read that if you overfill your fuel tank, it can leak out, so I figured I might of just overfilled the tank but now it is leaking again and i only have half a tank of fuel now.....what could this problem be? Any help will be more than appreciated!!!
rtw5634 is offline
post #2 of 12 (permalink) Old 07-22-2007, 11:19 PM
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Quoted: 8 Post(s)
IMO a leaking fuel is a serious problem have it check ASAP.
JOE55 is offline
post #3 of 12 (permalink) Old 07-23-2007, 07:11 PM
doin12volt's Avatar
Date registered: Apr 2007
Vehicle: 1995 C220 102k
Send a message via Yahoo to doin12volt
pm me with any ??'s..
http://www.benzworld.org/forums/w202...fuel-leak.html
http://www.benzworld.org/forums/w202...lutions-5.html
permalink #47
1995 C220 (W202)
Brilliant silver metallic
Viper Remote Start, Keyless and Security system
JVC KDAVX77 with DVD, BLUETOOTH and IPOD
Clarion component speakers
2 MTX 10" subwoofers - Vented
Total 500.1 subwoofer amplifier
17" MB wheels - 2002 E class / Chrome Star centercaps
Clear corner markers
35% Tint all around
LED 3rd brakelight
doin12volt is offline
post #4 of 12 (permalink) Old 07-25-2007, 05:36 AM Thread Starter
thanks, but it's not the main fuel line, that's what has me so confused about this
rtw5634 is offline
post #5 of 12 (permalink) Old 07-25-2007, 04:00 PM
oberoi's Avatar
Date registered: Mar 2006
Vehicle: 2010 C200 CGI /W203/SLK230/W202/230E/280SE
Quoted: 33 Post(s)
You had a look at the fuel filter and pump? - with the key turned on?
Try the charcoal canister connection - have you overfilled your tank lately? - canister might have been flooded - it's on the other side however
Maybe the fuel expansion reservoir connections
Oberoi
oberoi is offline
post #6 of 12 (permalink) Old 07-26-2007, 07:33 PM Thread Starter
it was the reservoir overflow and I have replaced the hoses to them with no leaking so far! now if i can only get the car to stop shaking in reverse so hard i will be set........ thanks for your help!
rtw5634 is offline
post #7 of 12 (permalink) Old 08-27-2007, 03:26 AM
Date registered: Aug 2007
Hi, Can anyone recommend a good set of manuals for a C250D similar to those screen shots above? in the UK we have Haynes manuals which are rubbish -
I have just changed the fuel filter but have no idea where the sealing washers go (only one on the unit I took removed), really need an exploded view of the assembly.
Thanks,
spock500 is offline
post #8 of 12 (permalink) Old 08-27-2007, 10:50 AM
lovemyc280's Avatar
Date registered: Oct 2003
Vehicle: 2004 Lexus LS 430 Modern Luxury. 2012 Acura TSX (fun fun) Maybe MB again one day...
Quoted: 69 Post(s)
Motor mounts?
lovemyc280 is offline
post #9 of 12 (permalink) Old 01-09-2008, 03:46 PM
Date registered: Jan 2008
Vehicle: 2003 MB c240
Send a message via MSN to sry281
i need help with charcoal filter location for c 240 2003 getting code 0446 i want to replace or should i do something else instead help needed
sry281 is offline
post #10 of 12 (permalink) Old 01-09-2008, 03:47 PM
Charcoal Canister not filter please help location of it and how to get to it
sry281 is offline
    96 C220 speedo odom and fuel gages on the frits Halakhb W202 C-Class 9 11-26-2008 12:30 PM
    C220 Fuel leak!! doin12volt W202 C-Class 4 05-04-2007 05:23 PM
    1995 C220 fuel pump sending unit prand W202 C-Class 1 02-18-2007 06:53 PM
    C220 CDi poor fuel economy mickdavies W202 C-Class 0 11-20-2006 09:49 AM
    Help, Vacuum leak C220 Fburns2027 W202 C-Class 2 09-27-2006 08:47 PM
