2000 C230 Kompressor Transmission Oil Change with Pics - Mercedes-Benz Forum
post #1 of 50 (permalink) Old 04-16-2007, 05:02 PM Thread Starter
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Vehicle: 2000 Mercedes-Benz S500. Sold: 2000 C230K, Sold: 1997 Porsche 944S
Quoted: 26 Post(s)
Send a message via Yahoo to Mercedes Benz of Florida
This past weekend I changed out my Transmission Fluid and Filter at 58K miles
It was a bit black, murky, a bit milky, but not burnt!
No doubt; even though MB HQ says "Lifetime"...no way!
Before car shifted; well, clunky.
Now after the Oil Change and Filter; she shifts smoothly and with more noticeable power.
Here is my attempt at loading up pictures.
I hope this helps someone, anyone out there.
Sorry I don't know how to put those arrow thingys on the
photo caption.
Car: 2000 Mercedes Benz C230 Kompressor
Pictures:
1-Zoom out view of Tranny
2-Removing Pan Bolts. 6 each of them. Note the Thread Lock on the
Pan Bolts
3-Let old Tranny Fluid CAREFULLY drip out in the corner.
4-This is the old Tranny Fluid MB Engineers say is "lifetime". Here it is
with only 58K miles on it
5-View of Transmission with old filter still attached.
6-Dirty, nasty Automatic Tranmission Fluid. Note the dirt and milky substance
7-Clean Oil Pan done with Brake Cleaner Spray and Lint Free Rags
8-Install New Oil Filter
9-Very Carefully and slowly pour in the new Factory A/T Fluid
Button everything up. Wipe down everything with rags sprayed with left over Brake Cleaner Spray and check A/T Fluid Level.
Enjoy the smooth shifting.
Enjoy the day.
I hope this helps a bit.
I'm an amateur but I tried.
Good Luck!
File Type: jpg 2000 MB C230 Kompressor Transmission Oil Change 002.jpg (165.3 KB, 7459 views)
File Type: jpg 2000 MB C230 Kompressor Transmission Oil Change 004.jpg (124.1 KB, 4859 views)
File Type: jpg 2000 MB C230 Kompressor Transmission Oil Change 005.jpg (166.1 KB, 4419 views)
File Type: jpg 2000 MB C230 Kompressor Transmission Oil Change 006.jpg (166.2 KB, 4335 views)
File Type: jpg 2000 MB C230 Kompressor Transmission Oil Change 007.jpg (180.4 KB, 7407 views)
File Type: jpg 2000 MB C230 Kompressor Transmission Oil Change 009.jpg (196.4 KB, 4778 views)
File Type: jpg 2000 MB C230 Kompressor Transmission Oil Change 011.jpg (159.9 KB, 4254 views)
File Type: jpg 2000 MB C230 Kompressor Transmission Oil Change 013.jpg (144.6 KB, 4677 views)
File Type: jpg 2000 MB C230 Kompressor Transmission Oil Change 015.jpg (149.5 KB, 10450 views)
Charles
New York City, NY
Richmond County
United States of America
Mercedes Benz of Florida is offline
post #2 of 50 (permalink) Old 04-17-2007, 07:28 AM
oberoi's Avatar
Date registered: Mar 2006
Vehicle: 2010 C200 CGI /W203/SLK230/W202/230E/280SE
Quoted: 33 Post(s)
Good one Charles!
By the way that old fluid still looked pretty red so couldn't have been too bad(or was it the flash?) -- I've seen it like chocolate with a green tinge!!
Next time I do mine I'm going to put a magnet in the pan like most other trannies
--trying to find out the optimal placement --anybody know?
Oberoi
oberoi is offline
post #3 of 50 (permalink) Old 04-17-2007, 11:22 AM Thread Starter
Quoted: 26 Post(s)
Originally Posted by oberoi
Good one Charles!
Oberoi
Oberoi; it wasn't TOO bad, but it wasn't what I expected.
I did inspect it and found it to not be burnt, which is a good sign.
Also inspected it for gritty, particulate matter, not too much.
But was dark brown, like chocolate and at times "milky".
I could not post all the pictures.
You know what's funny? Is you mention the Magnet.
I was thinking about that Yesterday.
Would love to have a 3"x5" magnet that I could attach.
However, knowing its a good idea, I just betcha the MB PURISTS will start yelling
" If a magnet was called for by the Engineers it would be in the Owners Manual"
followed by: "I would not do it..."
hahaha. LMAO
Thanks for your earlier HELP! It was spot on!
Charles
New York City, NY
Richmond County
post #4 of 50 (permalink) Old 04-17-2007, 10:18 PM
Benzonline's Avatar
Date registered: Oct 2003
very good!! I love to see a nice car like a W202 being taken care of. Ive done this last year but the dealer done it.
98 S420
99 C43 ////AMG
99 C230 Kompressor
02 C240
Former MB's:
83 380SEL
85 380SE
91 560SEL
02 C230K Sport Coupe
Benzonline is offline
post #5 of 50 (permalink) Old 04-18-2007, 09:35 AM
jlomon's Avatar
Vehicle: 2013 VW Golf Sportwagen TDI, 2011 Mazda 2, 2000 E320 4Matic Wagon (retired),1994 C280 (retired)
Thanks for the pictures. Just to make it a cleaner job for you next time, there is a drain plug in the bottom of the transmission pan. You can see it in your third picture. Instead of draining the fluid over the corner of the pan, you can just remove the plug and let most of it drain out. Much easier and cleaner.
jlomon is offline
post #6 of 50 (permalink) Old 04-18-2007, 03:37 PM Thread Starter
Quoted: 26 Post(s)
Yeah; I saw that drain plug.
I was attempting to screw it off, had a bit of resistance, then I changed my mind and said NO.
I was very concerned it was attached to something.
I did not know what that "drain plug" was attached to.
Of course, afterwards I saw there was nothing there.
Better to be safe than sorry right?
I'm happy with the way it went down. I cleaned the gunk out and NOW know for sure the fluid is fresh, vibrant and changed.
Next time, of course, I'll drain it first via drain plug, THEN remove the Drain Pan.
Charles
New York City, NY
Richmond County
post #7 of 50 (permalink) Old 04-18-2007, 08:38 PM
Benzonline's Avatar
What about the thermometer used for filling to the proper level and measuring at a certain temp?
98 S420
99 C43 ////AMG
99 C230 Kompressor
02 C240
Former MB's:
83 380SEL
85 380SE
91 560SEL
post #8 of 50 (permalink) Old 04-20-2007, 04:27 AM Thread Starter
Quoted: 26 Post(s)
How do you get the daggone Turkey Thermometer down into the tube orifice?
Charles
New York City, NY
Richmond County
post #9 of 50 (permalink) Old 04-20-2007, 08:39 AM
xvvvz's Avatar
Date registered: Sep 2006
Vehicle: '99 2.3L Kompressor
Infrared "point and shoot" type thermometer
xvvvz is offline
post #10 of 50 (permalink) Old 05-01-2007, 06:03 PM Thread Starter
Quoted: 26 Post(s)
I bought a Infrared Thermometer for Ten Dollars at Harbor Freight Tools
Oil Change was challenging, but not hard. A bit messy, but c'est la vie
All in all; awesome experience!
THANK YOU EVERYONE for your help!
Charles
New York City, NY
Richmond County
    2003 C230 Kompressor DIY oil change questions? spoons W203 C-Class 22 06-02-2015 05:10 PM
    Any tips for: DIY Oil Change: 98 C230 Kompressor sunnfyfx W202 C-Class 3 02-20-2007 10:20 PM
    c230 kompressor transmission failure w210 W203 C-Class 2 01-17-2006 01:50 PM
    Transmission oil change for 2000 ML-430 lakshs2003 W163 M-Class 1 09-10-2004 01:59 PM
    FOR SALE: C230 Kompressor 2000 smanar W202 C-Class 0 12-20-2003 10:33 AM
