Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W202 C-Class
Old 03-24-2007, 12:37 PM   #1 (permalink)
Date registered: Dec 2006
Vehicle: 2000 C280
Cleaned MAF sensor twice, no help.
I have a rough idle on the car and I have cleaned the MAF sensor twice now. The second time I removed it from the housing. Am I correct in thinking that once clean, I will notice an immediate difference on engine startup? If that is case then I must need to replace. Any thoughts?
oledale is offline   Reply With Quote
Old 03-24-2007, 01:47 PM   #2 (permalink)
Little_Jon's Avatar
Date registered: Mar 2007
theck your spark plugs, try injection cleanor and give it some RPM out the tank, try changeing your fuel filter
Little_Jon is offline   Reply With Quote
Old 03-24-2007, 02:29 PM   #3 (permalink)
Send a message via MSN to Raylee177 Send a message via Yahoo to Raylee177
Did your code reader say you have MAF problem? If it did, cleaning properly can work. Many peopl have done it including myself. Try using CRC and spray inside glassy area of the MAF real good. Some people have to take inserts out to clean it properly. Good luck.
Raylee177 is offline   Reply With Quote
Old 03-24-2007, 02:36 PM   #4 (permalink)
flapper1's Avatar
Date registered: Jun 2006
Sounds like something other than a MAF sensor... I would agree on checking your spark plugs.
flapper1 is offline   Reply With Quote
Old 03-24-2007, 04:38 PM   #5 (permalink)
Vehicle: 2000 C280
The code shown was P0170.
Would you get a CEL for a bad sparkplug?? Are the sparkplugs anything unusual?
I used the MAF cleaner twice. The second time I took the unit apart. BTW, I did not see any glassy area?
Old 03-24-2007, 04:47 PM   #6 (permalink)
flapper1's Avatar
p0170 is a fuel trim code. Though the MAF can cause this... also inspect for a vaccum leak, fuel injector problems, or a fuel delivery problem, such as a bad pressure regulator, or clogged fuel filter. Also, since you have a v6 and only show a fuel trim code for right bank... well, heres a tip... almost all mafs produced before 2001 are know bad units. I suspect since you have a 2000 my, you really should replace it if all else checks okay.
Old 03-24-2007, 05:27 PM   #7 (permalink)
Vehicle: 2000 C280
The idle reminds me of the problem I had in my 74 pinto.
It idled the same way and was caused by a vacuum leak.
Was there known problems with the MAF prior to 2001? How do you check this car for a vacuum leak?
Is the fuel filter easy to locate?
Old 03-24-2007, 08:24 PM   #8 (permalink)
flapper1's Avatar
fuel filter is forward of the left rear tire and is above that black plastic cover held on by 3 10mm plastic nuts. The fuel filter also has the integrated pressure regulator.
Simple way to check for vacuum leaks is to listen. You shouldnt hear abnormal hissing... like if you where to try and suck the air out of a jar with a hole in it, it would his. Look around vacuum lines and all the non coolant hoses. Also, spraying something such as carb clean around the engine, such as around the intake manifold gaskets, around vacuum lines, etc... if you have a vacuum leak the CARB clean will instantly send the car a little richer and the idle should change...
MAF in general are a problem, Im sure you could search for days about them here and everywhere else on the internet. I just know that post production 2001 they where very "finiky". Sometimes they would be bad and test good.
Hope all this info helps.
Old 03-25-2007, 09:53 AM   #9 (permalink)
Vehicle: 2000 C280
Okay, I will order a MAF from Autohauz tomorrow. I need to get the code reader to make sure it is the same code. Thanks for your help
Old 03-28-2007, 02:31 PM   #10 (permalink)
Vehicle: 2000 C280
Replaced MAF and car still has a rough idle. I haven't reset the code yet to see what appears, but I 'll try that next.
cleaned MAF, now rougher idle peckels01 R170 SLK Class 4 01-07-2007 07:00 PM
No Kompressor after installing cleaned MAF :-( mitaci R170 SLK Class 8 04-26-2006 02:59 PM
Where is the MAF sensor? DeathCannon R129 SL Class 11 10-17-2005 12:26 PM
Anyone need a MAF sensor? str8ridin W208 CLK Class 0 08-31-2005 12:07 PM
MAF sensor VS. K & N loudgmc W210 E-Class 1 02-19-2005 06:44 PM
