Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W202 C-Class
Old 11-30-2006, 05:34 PM   #1 (permalink)
Date registered: Jun 2006
Vehicle: Mercedes C220
Engine Noise
Hi All
There is some kind of noise coming from the engine compartment. Grrrrrr…. Period, Grrrrrrr.. period. (Hope it gives you a better picture of the problem). It is always present, but prominent after a cold.. It becomes more annoying when in D.The most I could isolate it is that it is coming from somewhere around thermostat. Also, when I touch the thermostat it gives out a good amount of vibration as if it is coming from thermostat itself. I changed the thermostat the other day(it was going bad), and for a short period(like 5 seconds) the noise was gone. It sounds pretty bad, could it be timing chain is skipping tooth? Or the tensioner shock.
1995-C220-178,000 miles
Thanks.
xplicit_nick is offline   Reply With Quote
Old 12-06-2006, 12:07 PM   #2 (permalink)
Date registered: Jul 2004
Vehicle: 98 C230k
Sounds like it could be the belt tensioner, maybe when you select D this lowers the engine revs and makes it more noticeable. I looked at a car once that I was going to buy it had similar symptoms and that was the tensioner.
Timbo
timbo is offline   Reply With Quote
Old 12-06-2006, 12:17 PM   #3 (permalink)
Vehicle: 1996 Mercedes Benz C280 Sport
Send a message via AIM to Matt09
Yeah. It just came up on me, and the noise was caused by the bearing in the belt tensioner.
Matt09 is offline   Reply With Quote
Old 12-06-2006, 10:56 PM   #4 (permalink)
Thanks Guys for your input, I would try to change it A.S.A.P and post the outcome.
Engine Noise dahappybanana W124 E,CE,D,TD Class 3 10-25-2006 10:37 AM
engine noise lander91 W126 S,SE,SEC,SEL,SD,SDL Class 4 09-24-2006 08:22 PM
engine noise help black cloud W123 E,CE,D,CD,TD,TE Class 1 07-12-2005 02:13 PM
Engine Noise NeilHRSA W124 E,CE,D,TD Class 0 01-02-2005 10:45 PM
engine noise adam G-Class 1 04-21-2001 11:50 PM
