Replacement Brake Pads for a C280 - Page 2 - Mercedes-Benz Forum
post #11 of 17 (permalink) Old 02-25-2011, 01:39 PM
Date registered: Feb 2008
can somebody give a quick "how to" on the FRONT brake pads for a C280 1999. Pictures are always wonderful. Thanks guys!
david83 is offline
post #12 of 17 (permalink) Old 02-25-2011, 03:03 PM
torrem3's Avatar
Date registered: Oct 2006
Vehicle: 95 C280, 89 300E, 94' E320 Coupe, 91' 560SEC
Quoted: 74 Post(s)
i think i have some pics, of when i changed my calipers, lines, fluid,resorvoir, pads, rotors and re-greased my wheel bearings, i can only load five pics a post so if you need any other angles let me know.
torrem3 is offline
post #13 of 17 (permalink) Old 02-25-2011, 03:23 PM
torrem3's Avatar
Quoted: 74 Post(s)
So get everything assembled and have a jackstand holding the car up when you do this.
Look on the forum for a good list of reliable brand of products or get OEM from the dealer. As you can see almost everything I got was from the dealer minus the Zimmermann Rotors, Rebuilt Calipers and High performance SuperBlue ATE brake fluid.
Once the wheel is off and jack is firmly in place. Clean up the area from any brake dust whether its brake cleaner or a good shop rag/towel you will the brake caliper is composed of two pieces. A floating set up. Use a penetrating lubricant to help break the bolts loose. The bolts hold that center portion of the caliper to the outer portion of the caliper( called an anchor). I dont remember what size those were. 13mm maybe but don't quote me. DO NOT REUSE THOSE BOLTS. You new brake pad sets should come with new bolts use them, they should have a dribble of blue locktite on them already. You will have to use a wrench and a rachet as the nut that holds onto the caliper "floats" in the caliper. Before lifting the caliper, unplug the sensors from the pads. Once the bolts are off lift the caliper off and DO NOT let it dangle as the brake line will be stressed and damaged hang it with something. I used a wire hanger to the coil. Surprisingly heavy so make sure it hangs.
The pads should be sitting on top of the anchor, take them off.
This is the anchor removed the back side of the anchor facing up. The small holes on the bottom being where the caliper bolts on the larger bolt holes are for bolting the anchor to the spindle. Needs only to be removed if replacing the Rotors as well. Again Dont remember the bolt sizes some one please help on this one. was it 17mm? The Rotor popped off after removing a small hex bolt that sits between the wheel bolt holes.
This should be what you are staring at when everything is off. It was a great time for me to re-grease my wheel bearings
So with everything off look at the caliper that's hanging it should contain a plastic cap on top. Pop open the cap and the brake sensors are there. Some say to just leave them be regardless of used or not. I like to change things just to save myself the headache. pop them off. When putting the new pads, be sure to add brake paste to the back of the pads, otherwise risk serious squeaks. Be liberal with the paste. reassemble in reverse order. I don't have the tightening torques on me. I essentially cranked the torque wrench to 60ft/lbs and went at it. But again don't quote me. I should have done this write up back in sep/dec when I remembered everything...
Oh and check the rubber boots on the anchor if they are torn, replace. I added some bearing grease to it and popped my new boots on as mine were torn
anyone care to chime in on the specs and bolts sizes. When I did this, it was my first time as well...
torrem3 is offline
post #14 of 17 (permalink) Old 05-07-2011, 01:04 PM
BenzHell's Avatar
Date registered: Feb 2009
Vehicle: 1994 C280 Sport Gunmetal Grey FULLY CUSTOMIZED
The light has gone on letting me know it's time to change the brake pads. I have a C280 1994 and was wondering what tools will I need to do this job and actually how to do it..?? I guess it is different than later models but I have no clue. Any help would be appreciated.
BenzHell is offline
post #15 of 17 (permalink) Old 05-09-2011, 05:06 PM
Date registered: Jul 2007
Akebono Eurospec. No dust, good stop!
marvinstockman is offline
post #16 of 17 (permalink) Old 05-09-2011, 05:25 PM
Date registered: May 2011
Vehicle: 2006 C280 4 Matic
Are Ceramic Pads Ok? 2006 C280
Does anyone know if we are not supposed to use ceramic replacement brake pads for a 2006 c280? Front. Or do I have to stay with semi-metalic?
LibertyChamp is offline
post #17 of 17 (permalink) Old 05-09-2011, 06:02 PM
torrem3's Avatar
Quoted: 74 Post(s)
Wrong forum try the W203 section, unless someone here knows about W203 brake tech
torrem3 is offline
    Brake Pads and Rotor replacement Front Bazzle R170 SLK-Class 47 12-20-2010 01:51 PM
    REPLACEMENT BRAKE PADS..DON,T GET RIPED OFF leslierushforth W211 E-Class 1 07-14-2005 09:52 AM
    Brake Pads & Rotor Replacement Experience tiger2doll W163 M-Class 3 09-16-2004 07:55 PM
    Replacement brake pads - E55 2000BEAST The Discount Tire Direct Tire, Wheel, Brake & Suspension 4 05-29-2003 12:31 PM
    ML320 rotor and brake pads replacement tabo W163 M-Class 14 03-31-2002 09:00 PM
