» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W202 C-Class
Old 08-07-2007, 07:44 AM   #41 (permalink)
Date registered: Dec 2006
MERCEDES WIRING HARNESS DEFECT
The ineptitude of this once mighty company is only matched by their arrogance and disdain for customers in handling this issue with the defective wire harnesses. Over 1.5 million vehicles are estimated to be affected and it's not a matter of IF but of WHEN your harness will fail.
Safety Defects have no statute of limitations. This has nothing to do with warranty, it's an engineering error that creates a potentially hazardous condition (engine fires, sudden stoppage in traffic, stranding in dangerous locales, etc). Mercedes is well aware of the problem they created and refuses to do the right thing which is recall all vehicles affected, not wait for the NHTSA to do it, nor count on naive customer/victims not to do anything about it erroneously thinking that the age of the vehicles is a factor.
I am collecting a list of like affected owners to pursue action against Mercedes for this safety defect.
Contact me at flyer_boy@hotmail.com
pepepotamo is offline   Reply With Quote
Old 08-07-2007, 04:17 PM   #42 (permalink)
'91 300CE's Avatar
Date registered: Jul 2006
Vehicle: 2000 C230K and 2002 ML320
Don't post the same thing in multiple areas of the same forum
2000 C230K -- Desert Silver Metallic
2002 ML320 -- Alabaster White
1991 300CE -- Blue Black Metallic -- 129,000 miles -- Sold
1981 300SD -- Classic White -- 190,000 miles -- Sold
1977 240D -- Over 300k miles (Wrecked) -- My 1st car
2005 Porsche Cayenne S - Dad's
2004 Porsche 911 Turbo S
'91 300CE is offline   Reply With Quote
Old 08-24-2007, 09:34 AM   #43 (permalink)
~BANNED~
benz rider's Avatar
Vehicle: 97'C280
corrosion on the wires comes from moisture that gets into the engine bay via rainstorms, etc...
as a preventive step, I plan to wrap the entire harness in electrical tape to keep the corrosion from building up in the first place. I don't plan on wrapping each individual wire since there is no need for that at this point. or ever....
benz rider is offline   Reply With Quote
Old 09-12-2007, 04:22 AM   #44 (permalink)
Date registered: Sep 2007
Repairing Engine Wire Harness
I recently bought a 1993 300e mercedes a week ago with the same electrical problem. It was not running at when I got It. After a little time in testing the wire which I was told by th privious owner was the problem, I was able to start the car. The problem are the plugs connected to the ignition coils. I did the same repair and it works. Repair plugs kits are also available at the mercedes dealership. At first the parts department is advising me to replace the enitre engine wire harness at costof $1800 Canadian (wow expensive for on old car).The repair plugs will cost is lesss than $100C. I will give you update when i get the parts. Things to do is to strip all the tapes on the harness and thinking of replacing with tubes instead of retaping. This way I will able to recheck and repair wires as needed.
raul21263 is offline   Reply With Quote
Old 09-12-2007, 04:31 AM   #45 (permalink)
I woud suggest to use the split plastic tube to cover the wires. This is available in any auto parts store. This way you can recheck your wires without removing the electrical tape.
Old 09-15-2007, 08:59 PM   #46 (permalink)
I also did repair my engine wire harness by raplacing each wire at a time. Splice a the ends to te plugs. Took meapproximatel 8 hours. this is is working only after office hours. Car start at first try.
I still have the idle surging.
My car failed aircare. I took my car to the repair shop for dignostic. The technician cannot do a proper diagnostic. The technician told me that there is still some shortage with the wiring.
I haven/t check the throttle actuator wiring yet.
I took a peak by cuttng a small cut the rubber casing. it seems that the insulators are gone too.
Is there a way testing wires for shortage?
Will the ECU be damage when there is wiring shortage?
Old 09-15-2007, 09:07 PM   #47 (permalink)
Originally Posted by junsoyao
I am confused regarding the wiring harness. Below is a link I found which sells the wiring harness for only $52.00. I am not sure this is the right one that you guys are discussing. Please advise.
Select Product
Thanks
That is the wrong harness.
Old 09-15-2007, 09:12 PM   #48 (permalink)
Originally Posted by Edumen
Made a new harness for my C-280, used the original connectors, spliced the wires (automotive heat ressistent) next to the plugs (connections) with solder and heat shrink tubing, took about 4 days to complete the project, car started on the first try, no trouble codes present, car is performing GREAT, car now has a steady idle of 550 rpm. Moral of this story ? You can DIY !
Ed
Removing the old one:
It's Off:
Repairing : Top of picture, Injectors and Coil plugs (red wire) repaired.
P.S It's important to take many pics, it helps solve repair and installation doubts !
I did the same procedure to my 300E. By replacing each wire at a time. I got replacement plugs connecting to the ignition coil from MB. Car started the first time. However, I still have the idle surge. I have not check the throttle actuator yet.
Old 09-16-2007, 05:22 AM   #49 (permalink)
Date registered: Mar 2006
Vehicle: 1996 Silver C36
raul21263,
You are one impressive auto electrician!
Rebuilding a C202 wiring harness? Thanks for the photographs and information sharing, but as far as I am concerned, your skills far surpass any that I could achieve!
Cheers,
OzC36
OzC36 is offline   Reply With Quote
Old 11-03-2007, 11:27 PM   #50 (permalink)
Date registered: Nov 2004
Originally Posted by doin12volt View Post
Anyone interested in a harness re-build service? I have been doing automotive electrical for the last 16 years, and I am a 1st class certified MECP technician.
I have all the supplies to do this, and i ONLY use solder and heat shrink tubing, NO CRIMP CONNECTORS!!!
Would $300 per harness and about a week turn-around time be decent?
What do you guys think, im just trying to help....
Are you still offering this service?
harvsc280 is offline   Reply With Quote
1993-1995 Engine wiring harness problems bcool R129 SL Class 99 09-07-2009 01:54 AM
MB Engine Wiring Harness Failure infoage1 General Mercedes-Benz 2 11-07-2008 05:31 PM
WTB: engine wiring harness Jippi For Sale, Trade & Wanted Items 0 01-31-2006 11:18 AM
engine wiring harness jeffreyli86 W124 E,CE,D,TD Class 10 04-21-2005 12:16 PM
Engine Wiring Harness issue benzpeice W124 E,CE,D,TD Class 10 02-23-2004 08:09 PM
