» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W202 C-Class
Old 08-18-2009, 11:21 PM   #191 (permalink)
carlo168's Avatar
Date registered: Sep 2008
Vehicle: 1986 190E 2.3-16
Hello All! I just bought a 99 c230 kompressor so far i havent had any problems with it other than the odometer which is almost out. By that i mean that the pixels on the lcd, some of them don't work and i can barely see the mileage which is about 121k. Any DIY tips on how to fix this? TIA
carlo168 is offline   Reply With Quote
Old 09-04-2009, 09:14 PM   #192 (permalink)
Date registered: Jul 2009
Vehicle: 2000 Mercedes C230 Kompressor, 2004 C320 4Matic
Originally Posted by k weathers View Post
I am just tring to see if anyone can maybe tell me what the problem is ,I have a 1999 c230 kompressor the all most of my electrical things,such as windows, door locks, turn signals, trunk release stopped working, can enyone help?
I would check battery grounds, other battery cables, terminals, and the battery itself. There may be enough of a voltage drop during cranking enging that causes other systems to fail. Hook a digital voltmeter to battery and crank and watch meter. Some cool meters-like I have-Have a min-max monitor which can capture lowest reading even if you can`t see it on the face of the meter. Fluke meters are the best tools to have around. Good luck
dieselman01 is offline   Reply With Quote
Old 09-04-2009, 09:18 PM   #193 (permalink)
Mine is a 2000 c230k with the same dash issues. I can do circuit board repairs if that is where the problem origionates, just would like if someone could point the right direction to the digital segments missing in odometer and temp guage. Thanks
Doug
Old 09-17-2009, 06:22 PM   #194 (permalink)
Question windows and central locking stops working
Originally Posted by benz rider View Post
check your fuses. replace em all. doesn't cost much. if that don't help it could be a vaccuum problem. might have to disconnect the battery for 30 mins and see if everything resets.
I have a 98 C180 and have been doing this for a month now.After connecting the battery again everything will reset and works fine for a few days, then the windows and cetral locking will stop working again..checked and replaced almost every fuse.
GeeCee is offline   Reply With Quote
Old 09-26-2009, 09:20 AM   #195 (permalink)
Vehicle: MB 190e 2.3 1990 and C280 1997
Problem: Cylinder #1 misfire, plug carbon fauled
Problem Cause: Ignition cables connected wrong
Solution: Connect them right
Just got my 1997 C280 which I bought dirt cheap with "problems with the injection ", had been struggling to find the problem for the last week now and had just resigned and was about to take it to a mechanic when I read a post here about "coil 1 powering 6"
Could'nt believe it was so simple, was just driving the car working properly for the first time and it went like rocket =)
I actually feel a bit sad for the guy who sold it to me
Spuno is offline   Reply With Quote
Old 10-09-2009, 10:33 AM   #196 (permalink)
Can anyone help!!! I have a Mercedes C180 "98 the central locking has stopped working and I can only open the door with the keys but I can not open the boot. when I press the remote to open the lights flashes and the inside lights comes on but the doors won't open. The problem is how do i open the boot using the key cause it seems not work opening the boot manually or is there another way.
Old 10-12-2009, 07:50 AM   #197 (permalink)
~BANNED~
benz rider's Avatar
Vehicle: 97'C280
then you have another issue. could be a fuse reacting to another fuse that's acting up.
my lighter fuse would blow everytime I replaced it instantly and it made my dash lights come on and off. so I just stopped replacing the fuse for the lighter.
benz rider is offline   Reply With Quote
Old 10-12-2009, 07:55 AM   #198 (permalink)
~BANNED~
benz rider's Avatar
Vehicle: 97'C280
MAF is finally starting to die @158,000 miles
my 97'C280 has never had the MAF changed since I bought it used at 75,000 miles. all I used to do was peridoically spray some MAF cleaner into it and let it dry. but just the other day I got the dreaded rough idle so I immediately placed an order for a new MAF for $133.00+ tax online.
Discount Auto Parts - Car Parts, Truck Accessories and Import Performance Parts at The Parts Bin
Old 10-18-2009, 02:16 PM   #199 (permalink)
Bimmerman4ever's Avatar
Date registered: Jun 2009
Vehicle: 96 C280 Sport / Sis' 00 E320 4M
Originally Posted by guls View Post
Other commom issuewhich I've with my 99 C280 is intermittently Power seats don't work.
Is there a link somewhere? I couldn't find one.
I have a problem with the leading edge of the lower portion of the drivers seat.
I hear the motor running but it doenst move the seat. The rear tilt works fine and also forward and back but not the front tilt.
I assume the cable end that inserts into the motor is stripped.
Past Euros: 85/88/89 BMW 325e/i/ix, 85/95 BMW 528e/525i, 93 MBZ 190E 2.6, 91 VW Corrado G60, 71 MGB-GT, 78 Fiat Spyder 124
Bimmerman4ever is offline   Reply With Quote
Old 10-19-2009, 06:20 AM   #200 (permalink)
Date registered: Mar 2008
Vehicle: 1999 ML320 1999 ML430 1984 Corvette
2002 c 320 BAS code
rayrod99m is offline   Reply With Quote
