» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W202 C-Class
Old 09-13-2005, 04:02 PM   #1 (permalink)
Date registered: Sep 2005
1999 C230 Rust Problem
I have a 1999 C230 with significant rust developing on the bottom panels of both rear door openings. In addition rust is occuring in the area just below the mid-line trim moulding on both the left and right read doors. Anyone else seeing this?
jfallon is offline   Reply With Quote
Old 09-13-2005, 04:19 PM   #2 (permalink)
JOESID's Avatar
Date registered: Jun 2005
Vehicle: 1999 C230K Sport
Send a message via AIM to JOESID
RE: 1999 C230 Rust Problem
[:(] I can't believe you posted this. I actually I thought I wrote this. I wrote the same thing on mbworld.org. I have rust at the bottom of two doors and under the door trim. I took the trim off, very simple, and was amazed at what I saw. I think I'm going to treat that area myself, as its hard to see from the outside. I have a 99 C230 as well.
- from what I have been told, the rust from under the trim is due to the trim vibrating against the door. To fix this I have applied a layer of duct tape behind the trim in an effort to cushion it....I dont know....
1999 C230 Kompressor Sport
JOESID is offline   Reply With Quote
Old 09-16-2005, 02:11 PM   #3 (permalink)
Yes I have been told that too... My rust is very visible curbside at both the bottom of the rear doors and beneath the trim moulding.
Old 09-19-2005, 04:18 AM   #4 (permalink)
Date registered: Aug 2005
Vehicle: 1999 Euro C280 Sport
I found this post (Detailing and Car Care)
"Go to any big auto parts store and get a "paint/rust removal pen". It looks like a mechanical pencil, but instead of "lead", it has a tight cluster of fiberglass fibers. Brush it back and forth across the affected spot, and it will remove the loose paint, rust, and any embedded wax/polish. When you're done, clean up the area with some alcohol, let it dry, and use some touch-up paint to cover the bare metal."
This will help
Eddie
Curacao is offline   Reply With Quote
Old 09-19-2005, 08:13 AM   #5 (permalink)
Date registered: Dec 2004
Vehicle: '93 300E 2.8
JOESID - 9/13/2005 7:19 PM
Is this the trim inside or outside the door? A friend has a '99 C230K with an annoying buzzing sound coming from somewhere inside the driver's door. Raising or lowering the window doesn't seem to affect the noise (other than adding wind noise when the window is down).
wadman is offline   Reply With Quote
Old 09-19-2005, 12:36 PM   #6 (permalink)
JOESID's Avatar
Its outside the door, sorry.
I popped the rust bubbles, sanded, and applied rustoleum(*sp). I am then going to paint + clear coat over. The paint is coming from LA, so with the hurricaine it has been delayed....
Old 09-23-2005, 01:22 PM   #7 (permalink)
Benzonline's Avatar
Date registered: Oct 2003
Vehicle: W203,W202,W126
In the inside part of the bottom of my drivers door there is a spot of rust. I did find sand embedded in behind the rubber gasket which triggered this for sure...and washed it all out and sprayed some rust inhibitor.
-=- MARKO -=-
*2001 C240*
*1999 C230 Kompressor*
*1983 380 SEL S-Class*
*1985 380 SE (parts)*
www.freewebs.com/c230k
Benzonline is offline   Reply With Quote
