Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W202 C-Class
View Poll Results:
0%
Voters: 0. You may not vote on this poll
Old 06-05-2005, 04:19 PM   #1 (permalink)
Date registered: Jul 2004
Send a message via MSN to poorsenti
how to replace spark plugs and where are the plugs in 1994 c280?
Hey, guys
Recently, my 1994 c280 with 98,000 miles ran into rough idle and hesitation problems. From the forum, I figured the first try I should take is to replace spark plugs. But I could not locate the spark plugs and I have no idea how to do the job. Any help would appreciated.
Thanks,
poorsenti
poorsenti is offline   Reply With Quote
Old 06-05-2005, 06:06 PM   #2 (permalink)
lovemyc280's Avatar
Date registered: Oct 2003
Vehicle: 1994 c280
RE: how to replace spark plugs and where are the plugs in 1994 c280?
The crossover tube has to come off. Very easy. Two nuts on the back (on top of the engine)maybe 8-10mm. Then stick your arm under the intake and unscrew the clamp with screwdriver (maybe 3 turns). Unsnap the Mass Meter on the left. Then pull up slowly. Should come up no problem.
Use allenbolt socket to remove the bolts holding the plate down.
Pull up, and there are your plugs.
The 3 black coil ends go bad and cause the stumble, they are 10 bucks each. Might as well replace the wires too. The torque on the plugs are 18 ft-pounds I think. The type of plugs and torque spec should be listed in the manual.
Hope this helps.
lovemyc280 is offline   Reply With Quote
Old 06-26-2005, 11:22 PM   #3 (permalink)
Date registered: Jun 2005
Would this be the same steps for a 99 C280?
jenjenstar is offline   Reply With Quote
Old 06-27-2005, 03:07 AM   #4 (permalink)
yes, same process - you might need to check the Mass Airflow Meter as this affects how well the car idles / performs generally
Fizzy is offline   Reply With Quote
