Old 06-11-2002, 08:49 AM   #1 (permalink)
Date registered: Dec 1998
Balding outside edge of tire
Hi everyone, my car is perfectly aligned, the tires properly inflated and i dont take corners fast, so why is the outside edge of my tire all worn out?? what can i do to stop this?
Old 06-11-2002, 09:26 AM   #2 (permalink)
Re: Balding outside edge of tire
I have the same problem. However, it was much worse when my idler arm bushing needed replacemnt. Make sure, that your front end is tight and that you do not need any new components (I suggest going to a shop for this).
Old 06-12-2002, 09:05 AM   #3 (permalink)
Sounds like you still are out of alignment. That is causing your tires to cup or wear out.
Old 06-12-2002, 09:37 AM   #4 (permalink)
Nope, had mine checked twice-it's aligned
