Old 01-07-2002, 09:51 AM   #1 (permalink)
Date registered: Dec 1998
'86 190e Ignition key problem- the key won't turn
Has anyone run into the following problem?: <br> <br> My key works to open the door but won't turn at <br> all when I put it in the ignition. I don't know <br> whether the key is worn-out or if the ignition <br> 'tumbler' is gone. <br> <br> Any thoughts. <br>
Old 01-07-2002, 12:02 PM   #2 (permalink)
Re: '86 190e Ignition key problem- the key won't turn
If the problem is the ignition tumbler, a spot of oil should help. If oil doesn't help, the tumbler is probably fine and the ignition lock probably needs to be replaced. We keep the ignition locks in stock.
Old 01-09-2002, 12:22 PM   #3 (permalink)
I have a car similar to yours. I have an old fashioned mechanic to disassembled ´the lock and with the key in the ignition sanded the picks in the lock, so they werent protruding. Since then no problem.<br> Enjoy the car - probably the greatest car in its size!!!
Old 02-22-2002, 04:15 AM   #4 (permalink)
...This will sound stupid but try jiggling the steering wheel while you turn the key, works for mine.
Old 04-01-2002, 12:29 PM   #5 (permalink)
i have the same problem!!<br> <br> how much r the ignition locks??<br> <br> are how much they cost?<br>
