Old 06-22-2008, 06:17 PM   #51 (permalink)
w201 Über Moderator
Kynyption's Avatar
Date registered: Jan 2006
Vehicle: 1985 w201 Euro 2.3-16vlv / 1992 w201 2.6 Sportline Manual
Send a message via ICQ to Kynyption Send a message via AIM to Kynyption Send a message via MSN to Kynyption Send a message via Yahoo to Kynyption Send a message via Skype™ to Kynyption
your 84 only has 4 speakers.
All 4"
You Can Find Me In The w201...
...Don't Forget to Add Yourself To The w201 Frappr map!...
...Coming soon Projekt Euro
Kynyption is offline   Reply With Quote
Old 06-23-2008, 08:11 AM   #52 (permalink)
Date registered: Mar 2008
Vehicle: 84 190D
perfect. And I can go how much bigger still looking stock?
jsbarks is offline   Reply With Quote
Old 06-23-2008, 08:26 AM   #53 (permalink)
rurlndum's Avatar
Speaker wiring
the drivers side front had two sets of leads going to the speaker? anyone know what the second set was for? It had a connector which I just disconnected.
The second set of leads were for the cellular telephone.
rurlndum
rurlndum is offline   Reply With Quote
Old 06-23-2008, 04:42 PM   #54 (permalink)
importfan21's Avatar
Date registered: Apr 2008
Vehicle: 1992 Mercedes-Benz 190E 2.3L
Send a message via AIM to importfan21
4 inchers are gonna have to stay in the front. However, I managed to get 5.25's in the rear deck. Also, I have tweeters in the front.
I never knew why my door speakers never worked until this thread....I always thought they were disconnected from the headunit, but I never checked. But now that I know of this magical amp, I'll see if everything's connected...and maybe even replace the amp. I'm currently in the process of completely redoing my audio....and I mean everything.
importfan21 is offline   Reply With Quote
Old 06-23-2008, 05:02 PM   #55 (permalink)
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280
6.5" rounds will fit in the rear shelf if surface mounted, not flushed. No metal cutting.
MTI is offline   Reply With Quote
Old 06-23-2008, 05:41 PM   #56 (permalink)
Really? I dunno about other 190s, but my rear deck where the speakers go looks kinda weird. There's these parallelgram-shaped speaker covers that "hook" into the rear deck (lots of these hooking points, hence lots of holes/cuts in the rear deck) and then there's a plastic "cup" that sits under the deck that supposedly holds the speakers...it looks non-OEM...If I were to go to 6.5", I'm afraid either the speakers won't fit in the plastic cradle thing or some of the holes in the rear deck will be exposed.
Also, I just finished tearing my trunk apart for the amp...couldn't find it. Diagram/pictures anyone? Known wattage of this amp?
Old 06-23-2008, 06:36 PM   #57 (permalink)
MTI
MTI's Avatar
On the later models that have the plastic molded "baskets" that attach to the underside of the shelf, the baskets can be removed and the shelf trimmed to fit the larger speaker on top.
