» Site Navigation
» Other Sites
Old 07-12-2000, 05:11 AM   #1 (permalink)
Date registered: Dec 1998
93 190E 2.3 several questions
1- At first the sunroof open and close ok but some times can't tilt. Couple days latter I realized that when it's closed, the rear edge is a little lowered then the roof. And now 95% of time when I close it, the rear edge is a lot lowered the the roof surface, to the level I think water can easily leak through. Anyone has this problem fixed by DIY? and how? Detail instruction will be great :)<br>PS: open and close still work OK. <br>2- This car still has carburetor. If I extent the air intake duct (the way Shawn Fog did to BMW if you ever heard of), will it gains any low end? How about noise? My sister is the main driver of this car, so I won't do it if it makes too much noise.<br>3- My first question couple lines below was about the temperature needle goes too high. I still hoping to get some ideas. If anyone does have any idea, I am very appreciate it.<br>Thanks in advance.<br>
Old 07-13-2000, 12:50 PM   #2 (permalink)
Some answers.
1- At first the sunroof open and close ok <br>but some times can't tilt. Couple days latter <br>I realized that when it's closed, the rear edge <br>is a little lowered then the roof. And now 95% <br>of time when I close it, the rear edge is a lot <br>lowered the the roof surface, to the level I <br>think water can easily leak through. Anyone has <br>this problem fixed by DIY? and how? <br>Detail instruction will be great :)<br>PS: open and close still work OK. <p>A. The alignment is out of whack. Unfortunately, I had<br>my mechanic fix it for me. Took him 20 mins. to remove<br>the headliner, align the roof and put everything back<br>together.<p>2- This car still has carburetor. If I extent <br>the air intake duct (the way Shawn Fog did to <br>BMW if you ever heard of), will it gains any <br>low end? How about noise? My sister is the <br>main driver of this car, so I won't do it if <br>it makes too much noise.<p>A. It won't make any difference in noise. <br>Performance wise, I doubt it will increase<br>anything. If it does probably 1-2hp max.<p>3- My first question couple lines below was <br>about the temperature needle goes too high. <br>I still hoping to get some ideas. If anyone <br>does have any idea, I am very appreciate it.<p>A. Like Frank said, it is normal. You've already<br>done what most people do to lower the temp. and/or<br>preventive maintenance as they call it. If the<br>temp is really close to red line, you're temp gauge<br>must be out of whack.<p>Regards,<br>Alan<p>
Old 07-13-2000, 11:26 PM   #3 (permalink)
Thank you. I will try the roof this weekends (eom)
: 1- At first the sunroof open and close ok <br>but some times can't tilt. Couple days latter <br>I realized that when it's closed, the rear edge <br>is a little lowered then the roof. And now 95% <br>of time when I close it, the rear edge is a lot <br>lowered the the roof surface, to the level I <br>think water can easily leak through. Anyone has <br>this problem fixed by DIY? and how? <br>Detail instruction will be great :)<br>PS: open and close still work OK. <p>A. The alignment is out of whack. Unfortunately, I had<br>my mechanic fix it for me. Took him 20 mins. to remove<br>the headliner, align the roof and put everything back<br>together.<p>2- This car still has carburetor. If I extent <br>the air intake duct (the way Shawn Fog did to <br>BMW if you ever heard of), will it gains any <br>low end? How about noise? My sister is the <br>main driver of this car, so I won't do it if <br>it makes too much noise.<p>A. It won't make any difference in noise. <br>Performance wise, I doubt it will increase<br>anything. If it does probably 1-2hp max.<p>3- My first question couple lines below was <br>about the temperature needle goes too high. <br>I still hoping to get some ideas. If anyone <br>does have any idea, I am very appreciate it.<p>A. Like Frank said, it is normal. You've already<br>done what most people do to lower the temp. and/or<br>preventive maintenance as they call it. If the<br>temp is really close to red line, you're temp gauge<br>must be out of whack.<p>Regards,<br>Alan<p><p>
Old 01-31-2001, 03:56 PM   #4 (permalink)
is this the same RN from the E36 board? (nt)
: 1- At first the sunroof open and close ok but some times can't tilt. Couple days latter I realized that when it's closed, the rear edge is a little lowered then the roof. And now 95% of time when I close it, the rear edge is a lot lowered the the roof surface, to the level I think water can easily leak through. Anyone has this problem fixed by DIY? and how? Detail instruction will be great :)<br>PS: open and close still work OK. <br>2- This car still has carburetor. If I extent the air intake duct (the way Shawn Fog did to BMW if you ever heard of), will it gains any low end? How about noise? My sister is the main driver of this car, so I won't do it if it makes too much noise.<br>3- My first question couple lines below was about the temperature needle goes too high. I still hoping to get some ideas. If anyone does have any idea, I am very appreciate it.<br>Thanks in advance.<br><p>
