Old 08-28-2008, 02:10 AM   #1 (permalink)
cjasinski's Avatar
Date registered: Aug 2008
Vehicle: '92 190E
4" Alpine Speakers?
I will be getting a system installed friday but bestbuy does not have any 4" speakers for the front of my car.
Has anyone installed one of these and can comment on if they fit in the dash/door?
Alpine Electronics of America, Inc. - SPS-400
Alpine Electronics of America, Inc. - SPS-10C2
So far I have two 6 1/2" Alpine SPS-600 for the back and two 12" Type-R with the MRP-M1000 amp going in and its not going to sound to great until I get the dash and door speakers in
Please feel free to comment, and yes I know I should be installing it myself, hopefully they won't mess up my dash!
cjasinski is offline   Reply With Quote
Old 08-28-2008, 08:47 AM   #2 (permalink)
importfan21's Avatar
Date registered: Apr 2008
Vehicle: 1992 Mercedes-Benz 190E 2.3L
Send a message via AIM to importfan21
They both can fit in the dash/door. But if you are installing them in the door, let the Best Buy guys know about the whole hidden amp thing in the trunk if those door speakers do not work already.
6.5" in the rear is fine.
P.S. You could do the speakers all yourself, save for the subs/amp and door speakers. Front and rear speakers are easy.
Last edited by importfan21 : 08-28-2008 at 08:49 AM. Reason: Don't put a sub in a 190...it's just ghetto if not done right. *Cough cough, Bob, cough cough*
importfan21 is offline   Reply With Quote
Old 08-28-2008, 09:14 AM   #3 (permalink)
355190E26's Avatar
Date registered: Oct 2007
Vehicle: 1989 Mercedes 190E 2.6
I have Alpine 4 in Type S speakers in the dash (the 2005 versions which are silver) and Alpine 6.5 Type S in the rear deck. In order to fit the front speakers, you have to trim off two of the metal mounting tabs. Once you get them in they're up pretty tightly against the speaker grilles
1989 Mercedes 190E 2.6 Diamond Blue Metallic
/////Alpine sound system, Euro lights/Smoked Corners, Hella smoked tails on the way
355190E26 is offline   Reply With Quote
Old 08-28-2008, 12:30 PM   #4 (permalink)
cjasinski's Avatar
Vehicle: '92 190E
Thank you for the reply, which one do you think would be best for the dash, I was thinking the SPS-400 because of the fitments issue you talked about and then the SPS-10C2 for the doors.
Or should I go with both the same?
Old 08-28-2008, 02:54 PM   #5 (permalink)
355190E26's Avatar
I would go w/ the SPS-10C2 for the dash since the woofer mounting depth is shallower than the SPS-400. Once you get the tabs trimmed off, it fits nice and snug.
As for the doors, I'm not sure since my 89 2.6 didn't come w/ the door speakers.
Old 09-01-2008, 10:47 PM   #6 (permalink)
cjasinski's Avatar
Vehicle: '92 190E
Just curious on how you got the speaker covers to go back on over the 6.5 Type S in the back as the bestbuy people installed them but couldn't fit them back on and it looks bad, I'll post some pictures tomorrow.
They seem to think that they can fit 5" in the doors but I told them only 4" will fit without modification, also if it matters I have a 92 2.6 190E.
Also has anyone had success with taking out the stock amp in the trunk and replacing with a 200w alpine amp?
Old 09-02-2008, 07:58 AM   #7 (permalink)
ducatipaso's Avatar
Date registered: Jul 2006
Vehicle: 1985 280TE, 1993 190E 2.6 5-gang + various other stuff
I just recently did a door speaker swap.
I installed some soundstream 4". The OEM speaker is actually 4.5".
4" required a bead of silicone around the edge to seal it.
If you want to remove the amp and replace, you will need to pull a RCA line from the deck to the trunk. The amp is behind the right rear trunk liner. You can use the wires from the trunk to feed back to the doors and the rear.
Here's some pictures.
headunit mess when I got the car.
cleaned up with nice retro headunit installed
here's what a stock door speaker box looks like. The drivers are decent quality.
here's the size of the driver in the box
heres how they look with the 4" installed
heres what the oem amp looks like
here's where it goes
if your headunit has enough juice, you can drive the doors with it easily like this by bridging hi-level out from the headunit [powers the oem amp] and running it right back into the door speaker lines. works for my setup fine but I dont listen loud. long-term I'll be installing an amp in the trunk.
hope this all helps out.
eurocrap
ducatipaso is offline   Reply With Quote
Old 09-02-2008, 08:01 AM   #8 (permalink)
ducatipaso's Avatar
Old 09-02-2008, 09:13 AM   #9 (permalink)
355190E26's Avatar
I wound up using the Alpine speaker grilles instead of the stock ones. On the pre 90 models, the stock speaker size is 4 inches, so it's pretty much useless for bigger speakers.
Old 10-21-2008, 09:23 PM   #10 (permalink)
east7euro7united's Avatar
Date registered: Oct 2008
Vehicle: 93' 190e 2.6l
im a best buy car audio employee they think 5" will fit stock, but they wont ofcourse the guide at work tells us that 5 1/4s are in the doors and 6.5s in the rear and no info on the dash speakers. so that explains that just tell them their wrong haha
east7euro7united is offline   Reply With Quote
FS: CD Changer, Alpine AMP, W203 Speakers, Free Shipping on Everything paypaboi For Sale, Trade & Wanted Items 7 10-27-2008 01:40 PM
Boston Acoustic or Alpine Speakers Addbhp W124 E,CE,D,TD Class 11 04-04-2007 01:36 AM
W124 Alpine or Boston Acoustic Speakers Addbhp Audio & Telematics Forum 1 03-24-2007 10:02 PM
I was able to get 4 x 6 Alpine speakers in the front Bruce SEA 993 W126 S,SE,SEC,SEL,SD,SDL Class 10 05-04-2006 05:56 AM
alpine front dash speakers ButteryBenz W201 190E, D-Class 6 06-01-2005 01:14 PM
