Old 07-02-2008, 07:55 PM   #1 (permalink)
Loveofmylife190e's Avatar
Date registered: May 2008
Vehicle: 91 190e 2.6, 93 toyota paseo, 2001 nissan maxima.
Angry NEED A LITTLE HELP WITH RADIO
Restoring a 91 190 2.6 and everythin is going great. new remote starter, and keyless entry...radio worked fine untill i pulled it out and made space for a double din touch screen with navi. shorted out a wire and now i cant get the switched 12+ to turn on the radio. Constant is working fine,,,,i have changed and replace each and every fuse to no avail and am getting sick.
where and what is the fuse for the 12+ switched line, is it hidden some where or is a relay?
Loveofmylife190e is offline   Reply With Quote
Old 07-02-2008, 10:47 PM   #2 (permalink)
w201 Über Moderator
Kynyption's Avatar
Date registered: Jan 2006
Vehicle: 1985 w201 Euro 2.3-16vlv / 1992 w201 2.6 Sportline Manual
Send a message via ICQ to Kynyption Send a message via AIM to Kynyption Send a message via MSN to Kynyption Send a message via Yahoo to Kynyption Send a message via Skype™ to Kynyption
Your cig lighter work?
You Can Find Me In The w201...
...Don't Forget to Add Yourself To The w201 Frappr map!...
...Coming soon Projekt Euro
Kynyption is offline   Reply With Quote
Old 07-03-2008, 12:28 AM   #3 (permalink)
Radio Switch 12+ is gone
havent check but pretty sure it does because everything elde isok and no fuse is gone. i cleaned all contacts and replaced them all.
HHHEEEEELLLLLLLP
Old 07-03-2008, 10:58 AM   #4 (permalink)
Jippi's Avatar
Vehicle: 1996 Volvo 855 GLT, 1993 Mercedes-Benz 190e 2.3 8v
Send a message via AIM to Jippi Send a message via MSN to Jippi
did you put a volt meter to the wire? are you sure you have the right wire?
Jippi Jak
1993 MB 190E 2.3---Car's naked...
1996 Volvo 855 GLT--Project R clone
Benzworld.org---Jersey Crew
Jippi is offline   Reply With Quote
Old 07-03-2008, 03:27 PM   #5 (permalink)
not a volt meter, but my other accesories are connected to the same wire and they worked any time the ignition was switched untill i pulled the radio i think i blew a fuse but dont know which or what number goes to the switched 12+ or is it a relay?
Old 07-03-2008, 10:37 PM   #6 (permalink)
w201 Über Moderator
Kynyption's Avatar
You need to answer my cig lighter question before i will help you any further.
Old 07-04-2008, 07:36 AM   #7 (permalink)
Post ok so the cig lighter doesnt work.
Oh shit ok Cig lighter doesnt work after all...sorry i had to plug in a lighter to check.
so what do i do now
Old 07-04-2008, 08:36 AM   #8 (permalink)
w201 Über Moderator
Kynyption's Avatar
Fuse Number
13
Red
Diagnostic, hazard warning system, clock, trunk light, roof light front, illuminated vanity light, radio, automatic antenna
19
Red
Cigar lighter, glove box light, switch heated rear window, radio, sliding roof
Check them both. Pull the fuse out and throw a new one in. Even if it looks good.
Old 07-04-2008, 09:13 AM   #9 (permalink)
thanks
thankx am @ work now and will do that soon as i get home.
Old 07-05-2008, 07:41 AM   #10 (permalink)
yeah ok, so i changed both fuses for the radio. 12+ is great, 12+ switched still dead. OOOMMMMGGG is there a fuse or relay supplying it power that am missin?
Radio Reset Tool for W124 factory radio (i.e. bekker) rcs hawaii W124 E,CE,D,TD Class 2 05-01-2004 03:26 AM
Radio harness for upgrading my factory Panasonic radio roxu W163 M-Class 6 03-16-2004 04:14 PM
Do they advertise the SLK on the radio? They are heavily pushing the Z3 in my local radio stations> Max R170 SLK Class 7 07-02-2002 07:47 AM
Can I add other radio to my stock radio?(2002 CLK320) Guest (MBNZ) Audio & Telematics Forum 2 02-13-2002 08:04 PM
1995 E320 Radio - How to Set Radio Stations??? Guest (MBNZ) Audio & Telematics Forum 3 01-15-2002 11:24 AM
