» Site Navigation
» Other Sites
Old 06-19-2008, 02:19 PM   #1 (permalink)
jdjones2001's Avatar
Date registered: Jan 2008
Vehicle: 1993 190e 2.3
Question head bolt torque question
here's what the pdf manual says-
tighten cylinder head bolts in stages in the order of the tightening diagram, beginning with 1.
1st tightening state 55 Nm
2nd tightening stage 90 angle of rotation
3rd tightening stage 90" angle of rotation
so my question is twofold-
- those 2nd and 3rd stages, they are literally a 90 degree turn from where 55 Nm (about 40 lbs/ft) leaves off , and then 3rd stage a 90 degree turn from the end of the 2nd stage 90 degree turn?
and
if that is so, anyone have those figures in Nm or lbs feet?
I just wanted to make sure I wasn't overtorqueing and ruining everything.
BAM
jdjones2001 is offline   Reply With Quote
oil leak...usual suspects?, head-bolt torque? Rickysa W126 S,SE,SEC,SEL,SD,SDL Class 3 01-31-2008 09:50 AM
brake caliper bolt torque bobbydascout W203 C-Class 0 12-15-2007 11:26 AM
Banjo Bolt Torque... to loss W123 E,CE,D,CD,TD,TE Class 4 08-28-2007 04:18 PM
Valve Bolt Torque to loss W123 E,CE,D,CD,TD,TE Class 4 08-28-2007 04:07 PM
M180 Head Bolt Torque unimogjohn Unimog 1 11-18-2005 05:53 PM
