Old 06-07-2008, 03:40 PM   #1 (permalink)
Wild Child's Avatar
Date registered: Mar 2008
Vehicle: 1989 190E 2.6
Solved....A/C Question....
Ok heres the deal, charged the ac, compressor kicks on and off, wont run constant.Any ideas what could be the issue. Possibly ac speed control sensor?
WC
Wild Child is offline   Reply With Quote
Old 06-08-2008, 01:25 PM   #2 (permalink)
Date registered: Jun 2006
Vehicle: 2.5-16 (1990) SL500 (2000)
I had a leak in the SLS pump which dropped oil onto the belt.
AIRConditioning would not run until driven at least 10km.
It might not be your problem but it took a while to find.
Paul E is offline   Reply With Quote
Old 06-08-2008, 08:20 PM   #3 (permalink)
shingleback's Avatar
Date registered: Apr 2006
Vehicle: '87 190D 2.5 Turbo, '03 3.2TL-S 'A-Spec'
A short cycling issue is usually due to a low charge. How much did you put in?
shingleback is offline   Reply With Quote
Old 06-09-2008, 04:01 AM   #4 (permalink)
Wild Child's Avatar
I put in one small can 12-13 ounce and a 15 ounce.
Old 06-09-2008, 04:09 AM   #5 (permalink)
1987190E2.6's Avatar
Date registered: Nov 2007
Vehicle: 1987 Mercedes-Benz 190E 2.6
Here's my problem. A/C blows hot when idling, but blows cold when moving. And I don't know where to find R 12.
1987190E2.6 is offline   Reply With Quote
Old 06-09-2008, 05:54 AM   #6 (permalink)
Wild Child's Avatar
You'll have to have that one serviced by a mechanic that has the liscencing to recharge r12, or have it converted over to r34. Not sure about the idle/hot,moving cold, possibly it needs to build up pressure or possibly a leak in the system.
WC
Old 06-09-2008, 03:59 PM   #7 (permalink)
Wild Child's Avatar
Fixed today for 287.00... One of the fan's wasn't working as it should, replaced OEM.
WC
Resetting FSS question (error code question) TheOgre W163 M-Class 7 04-25-2008 01:37 PM
Shocks question/advice? RAYMOND, a question for you too! Cancer_Researcher W210 E-Class 10 03-11-2008 01:15 AM
Plug and Play NAV Question.First '05 Mod Question Stewart W163 M-Class 5 11-21-2005 08:00 AM
H&R Springs question --> General suspension question.. Vik W163 M-Class 4 01-31-2005 10:14 PM
EZ PASS QUESTION / ENGINE TEMPERATURE QUESTION Chucky300 W220 S-Class 1 04-15-2003 06:23 PM
