Old 06-08-2008, 08:24 AM   #11 (permalink)
Date registered: May 2008
Vehicle: 1991 190E 2.3l
Originally Posted by gonzalr1 View Post
i have bought lots of 190-e cars and noticed that temperture does rise when stopped with traffic,what i do to my cars ,i take thermostat off!and install relay switch to control fan on when i start engine evertime.but you got to understand that where i live tempature is 100 to 112 summertime and before.the only problem with no thermostat is when it does get cold ,it takes longer for hot air to heat up inside your car,but with no thermostat it keeps motor cooler circulating faster
Thanks Gonzair. Here in Finland, the summer never gets that hot(only about 20-30C) and traffic overheating is a tedious probelm. The overheating is tedious but I would rather have fast heating in the wintertime. Since Winter is long and hard here!
I will keep your advise in mind and opt in for it if needed. BUT, do you have instructions for the DIY relay switch to control the fan anyways?
Nepenthe73 is offline   Reply With Quote
Temperature gauge, Fuel gauge, Speedometer and Tachometer are all Dead tim995785 W210 E-Class 9 05-23-2008 01:23 PM
Temperature gauge, Fuel gauge, Speedometer and Tachometer are all Dead tim995785 W124 E,CE,D,TD Class 1 05-04-2008 03:17 PM
WTB fuel, Oil Pressure and Temp gauge Oneyeopn For Sale, Trade & Wanted Items 1 08-24-2006 05:38 PM
fuel/oil/temp gauge Logon_Bob W201 190E, D-Class 4 01-20-2006 04:07 PM
Problems fitting 500 fuel gauge-oil pres'-water temp gauge cluster to 560 clocks mutley666 W126 S,SE,SEC,SEL,SD,SDL Class 2 10-10-2005 09:03 AM
