» Site Navigation
» Other Sites
Old 05-18-2008, 04:00 PM   #11 (permalink)
purrp's Avatar
Date registered: May 2008
Vehicle: 1989 190E 2.6
Maybe it was for a cassette changer? I don't even know if the 1989 model had CD players as an option.
At any rate, I installed the radio and left the mystery wire alone, and the radio works great. It's running on 2 channels but it sounds good, I'm not an audiophile... I might run new wires to the speakers, but that'll be more for an excuse to tinker with it
Here are some more pictures for anyone else who might need them:
These are the wire harnesses, on the left is the car-specific harness from Crutchfield, on the right is the player-specific harness that came with the Sony player.
Roughly from top to bottom, the wires are:
Yellow - 12 volts constant power
Orange - illumination - not used by the Sony player, I just taped it off
Red - 12 volts switched power
Black - Ground
These 4 connect to the plug on the left in my first picture in this thread.
Blue - power antenna control (connect to middle wire in my first picture in this thread - more on this one later)
Blue/white - amp control (unused for me)
Gray + Gray/black - front right speaker - connected to "right" (black) speaker connector in car
Violet + Violet/black - back right speaker (unused for me)
Green + Green/black - back left speaker (unused for me)
White + White/black - front left speaker - connected to "left" (white) speaker connector in car
The power antenna wire from the Sony harness gave me a bit of trouble. It looks like this:
which doesn't really fit with the middle wire from the first picture. I had to cut it and crimp a male connector instead:
One last thing - the panel underneath the radio has two plastic hooks which go up into two holes in the bottom of the factory-installed player. The new player doesn't have those holes, meaning the panel can't slide all the way up, meaning I couldn't put the ashtray back in. I saw no other option but to amputate. This is the back of the panel after the operation:
And finally, the finished product:
It's not much to look at, but it probably fits better with the car interior than a flashier Alpine player.
purrp is offline   Reply With Quote
Old 05-18-2008, 05:07 PM   #12 (permalink)
355190E26's Avatar
Date registered: Oct 2007
Vehicle: 1989 Mercedes 190E 2.6
Glad to see the radio installation job went smoothly. I did the same thing that you did w/ the antenna turn on lead and crimped a male connector on it as well.
Definitely make your next project to run new speaker wire throughout the car into a 4 channel setup. There are various write ups on this board about doing that.
1989 Mercedes 190E 2.6 Diamond Blue Metallic
Alpine CDA-9883 w/iPod interface, paired w/Alpine Type S speakers, Alpine 4 channel amp,Euro lights/Smoked Corners, Red Smoked taillights
355190E26 is offline   Reply With Quote
Old 05-18-2008, 05:28 PM   #13 (permalink)
Jippi's Avatar
Vehicle: 1996 Volvo 855 GLT, 1993 Mercedes-Benz 190e 2.3 8v
Send a message via AIM to Jippi Send a message via MSN to Jippi
nice, in the states here we dont have harnesses.. they tell me that all the older benzes they re-wire the whole car. my alpine isnt flashy.....lol
Jippi Jak
Totaled 6-27-05: 1985 MB 190e 2.3
1987 MB 190e 2.3-- sold
1993 MB 190E 2.3---work in progress
1996 Volvo 855 GLT
I need a benz bad........
Jippi is offline   Reply With Quote
Old 05-18-2008, 06:46 PM   #14 (permalink)
purrp's Avatar
I stand corrected, an Alpine looks good in there too
To be honest, I like the looks of the Alpine units more, the main reason I went with the Sony was for the aux-in and the USB port.
Old 05-18-2008, 06:48 PM   #15 (permalink)
355190E26's Avatar
Actually the harness for the 190E is available from Crutchfield.com. When I ordered my Alpine HU from them, they threw it in for free as well as vehicle specific instructions on how to install it in the W201.
And this is my Alpine HU. I think the newer ones are a lot flashier than the older ones.
Old 05-18-2008, 07:38 PM   #16 (permalink)
Jippi's Avatar
yea not many companys have harnesses for them crutchfield is an exception. my alpine is an 03 model. i need to get an ipod cable for it..
Old 05-18-2008, 07:55 PM   #17 (permalink)
355190E26's Avatar
yeah definitely get the Alpine iPod controller. IMO they make the best iPod control interface. my fav part of it is the "percentage search" where the preset buttons allow you to find stuff quickly w/0 scrolling thru a long list
Old 05-19-2008, 06:10 PM   #18 (permalink)
frenchmanremy@hotmail.com's Avatar
Date registered: Apr 2008
Vehicle: 1986 Mercedes-Benz 190E 2.3-16V (3.0 Inline 6 swap)
guys, i wired everything according to that, and since the old owner was a retard and didn't check for a wire harness before butchering the car's wiring, now i have to hard-wire my stereo in. i plugged it accordingly with:
CAR - Stereo
Yl/Gr/Blk - RED(ACC)
Red - Yellow(memory)
Brown - BLK(Ground)
and still the radio won't turn on, everything is plugged and should work.
if i wire it as memory and constant power all together with the illumination, then it works but i have no memory on the head unit, and it turns on when my lights are on(go figure) .
i went through the wiring diagrams over and over, and staring at them seems a waste of time. help?
frenchmanremy@hotmail.com is offline   Reply With Quote
Old 05-19-2008, 06:33 PM   #19 (permalink)
Jippi's Avatar
check the fuses or you have a busted stereo
Old 05-19-2008, 06:43 PM   #20 (permalink)
stereo works fine when plugged to my other car, and the fuse#19(for interior stuff incl. stereo) is in and working.
like i said, if i wire it properly, it doesn't work, but if i wire is improperly, all power togethers, then it works, but i don't have memory..
1989 190e FS andrewk W201 190E, D-Class 24 07-02-2007 03:10 PM
Help Electrical !!!!!190e 2.6 1989 The Melmaan W201 190E, D-Class 10 12-23-2006 11:32 PM
PARTING OUT TWO 1989 190E 2.6 DA93BENZ190 W201 190E, D-Class 0 11-01-2004 09:00 PM
Tune Up for a 1989 190E 2.6 rod528 W124 E,CE,D,TD Class 0 08-25-2004 11:04 AM
1989 190e 2.6 Guest (MBNZ) W201 190E, D-Class 1 02-19-2001 03:22 PM
