» Site Navigation
» Other Sites
Old 05-14-2008, 07:25 PM   #1 (permalink)
Date registered: Feb 2008
190 D rocker panel replacement???
Does anyone know where u can buy the lower rocker panels on a 190d? Im talking about the whole panel. My 190 is rusted out at the jackpoints, the jackpoints are fine but the sheet metal around them is junk. Worse case Im going to cut it out any elimate those jack points...basically cover them up, but if I can get that part I will save them.
Thanks
Kevin
tryagn5 is offline   Reply With Quote
Old 05-14-2008, 07:36 PM   #2 (permalink)
ML Precision's Avatar
Date registered: Apr 2008
Vehicle: 1999 ML430; 1988 190E 2.3; 1993 XL883
I've seen that area rust out. I haven't seen that panel for sale, but you could Bondo or possible fiberglass around the jack point to fill in the void. Then spray the whole bottom panel with a fresh coat of paint. I would leave the jack point, you may need it someday.
ML Precision is online now   Reply With Quote
Old 05-14-2008, 10:03 PM   #3 (permalink)
shingleback's Avatar
Date registered: Apr 2006
Vehicle: '87 190D 2.5 Turbo, '03 3.2TL-S 'A-Spec'
Welcome to the forum Kevin; pls complete your profile so we know where you are and what you drive.
For the rocker panels you can right here: Sherman Parts - Product List
You want the first 2 items; they are called lower sill, and are $41 each.
shingleback is offline   Reply With Quote
Old 05-16-2008, 04:32 PM   #4 (permalink)
Re: Shingleback
Thanks for the link to the lower sills, nice price !
Old 05-16-2008, 06:13 PM   #5 (permalink)
Originally Posted by ML Precision View Post
Re: Shingleback
You're welcome; just don't buy them out...I still need to buy a pair for myself!
Old 05-16-2008, 08:04 PM   #6 (permalink)
thanks!!
I ordered a set today, so when they come in I will weld them in. More in likely i will only replace the rusted section, no need to cut the entire thing out.
Rust - Rocker Panel/Floor Pan Replacement acarless R/C107 SL/SLC Class 7 03-22-2008 07:06 AM
Rocker Panel TSWIFT W124 E,CE,D,TD Class 2 05-14-2007 11:06 AM
rocker panel? zazeem W126 S,SE,SEC,SEL,SD,SDL Class 3 04-08-2006 11:08 AM
Rocker panel papadude21 General Mercedes-Benz 14 01-07-2004 02:04 PM
Rocker panel papadude21 W124 E,CE,D,TD Class 0 12-30-2003 08:49 AM
