» Site Navigation » Other Sites
05-12-2008, 02:54 PM
#1 (permalink )
Date registered: May 2008
wheel bearing, ball joint, tie rod end? there is a play when you wiggle the tire. both ways. up and down and side to side.
05-14-2008, 07:45 PM
#2 (permalink )
Date registered: Apr 2008
Vehicle: 1999 ML430; 1988 190E 2.3; 1993 XL883
With the front end on jack stands, you can go under the car and have someone move the wheel and be able to see both the ball joint and tie rod. Check them for movement.
I had the same issue with mine. It was the wheel bearing. The bearing was fine, I just greased it and tightened it up to the manual specs. I don't know the specs off hand, sorry.
05-15-2008, 06:37 PM
#3 (permalink )
Thread Tools Display Modes Linear Mode
Similar Threads Topic Author Forum Replies Last Post wheel bearing, front axle or tie rod end? ritchi3 W201 190E, D-Class 7 05-12-2008 11:26 PM tie rod ends and lower ball joints Tephra W124 E,CE,D,TD Class 13 04-14-2008 03:12 AM tie rod end to wheel clearance ducatipaso W123 E,CE,D,CD,TD,TE Class 5 02-18-2008 11:05 AM Tie rod ends & Ball Joints dannyqball_817 W163 M-Class 3 05-12-2007 07:50 AM Help, still trying to locate front end noise...changed ball joint, tie rod... russ g W126 S,SE,SEC,SEL,SD,SDL Class 4 08-12-2006 01:53 AM
