» Site Navigation
» Other Sites
Old 05-15-2008, 08:34 AM   #11 (permalink)
shingleback's Avatar
Date registered: Apr 2006
Vehicle: '87 190D 2.5 Turbo, '03 3.2TL-S 'A-Spec'
Here are a couple of pics to show you where the rod is connected. Also, look at the pic you posted...the one that shows you holding the lock in your hand. There is a plastic cover on the back that needs to be popped off with a screwdriver, and you will see where the rod is connected.
shingleback is offline   Reply With Quote
Old 05-15-2008, 10:00 AM   #12 (permalink)
Jippi's Avatar
Vehicle: 1996 Volvo 855 GLT, 1993 Mercedes-Benz 190e 2.3 8v
Send a message via AIM to Jippi Send a message via MSN to Jippi
the little yellow circle is where the clip is that holds the cover in place
Jippi Jak
Totaled 6-27-05: 1985 MB 190e 2.3
1987 MB 190e 2.3-- sold
1993 MB 190E 2.3---work in progress
1996 Volvo 855 GLT
I need a benz bad........
Jippi is offline   Reply With Quote
Old 05-15-2008, 08:07 PM   #13 (permalink)
mcimichell's Avatar
Date registered: Dec 2007
Vehicle: Mercedes 86 190E 2000 cc
Send a message via ICQ to mcimichell Send a message via AIM to mcimichell Send a message via MSN to mcimichell Send a message via Yahoo to mcimichell Send a message via Skype™ to mcimichell
Thanks guys! I also took off the cover, but didn't find the place where to connect the rod!
Maybe it broke off, like Shingleback said, but I'll open it again and double check!
Also: my cover doesn't leave any space where to slide in the cover, maybe I don't remember right! I even remember of having a dent that fits into a hole on that side!
But now I realized that I can tight the screw without taking off the trunk lock, so I'll check that way!
Thanks as usual, guys, I'll let you know!
Ciao, Massimo - Italy - Perugia (Center)
Mercedes 190E 2.0 (w201 024), year 1986 - Fiat 850 Sport Coupè 900 cc, year 1970,
Ford Transit (van) 2,400 cc, year 1979 - Suzuki GS750E 750 cc, year 1980,
Fiat Uno Fire 1,000 cc, year 1990 - Bayliner Avanti 3055 7.4L BravoII 7.400cc, year 1991
mcimichell is offline   Reply With Quote
Old 05-16-2008, 06:26 AM   #14 (permalink)
drewprof's Avatar
Vehicle: 560SEL, 190E, RX7
There is a screw holding the the arm connecting the air activated mechanism and the lock mechanism. On my car when I removed the cover behind the lock assembly that screw fell right into my hand. Once I put that screw back up the trunk would lock properly
I will take some pictures once the weather gets better here, it's raining kittens and puppies right now.
drewprof is offline   Reply With Quote
Old 05-22-2008, 05:04 PM   #15 (permalink)
mcimichell's Avatar
Mine has no place for the screw!!
You can look in the pic yourself!
I have to look for one in a junkyard, so I can exchange the parts!
Old 05-22-2008, 05:15 PM   #16 (permalink)
drewprof's Avatar
The second picture that you took that's out off focus; that's where the screw goes.
The arm goes inside the assembly and connects to the plastic tit, then the screw goes over the tit keeping the arm in place.
Old 05-22-2008, 06:59 PM   #17 (permalink)
mcimichell's Avatar
In the second one you can also see that I have a dent over there,... maybe I have to cut it and make some space where the rod extremity moves...
But in the first one you can see that where it should be connected there is no place for the screw... I might try to drill a hole and stick it there.
But ... again, the rod should push to open and pull to lock, like the doors? Vice versa? I have to study on it!
Mmmm... I better go to a mechanic that knows how, I guess! :/
FS: Door lock actuator MLMoose W163 M-Class 3 08-02-2008 08:50 PM
trunk lock actuator THIS SUCKS!!! en-em W163 M-Class 3 06-26-2007 06:53 AM
Again I ask: Lock Actuator TheGodfather W163 M-Class 3 06-07-2007 05:35 AM
Door Lock Actuator Repair Help MarkR W163 M-Class 1 10-24-2004 09:11 AM
Need a trunk lock actuator chillinsound W123 E,CE,D,CD,TD,TE Class 1 08-31-2004 09:07 AM
