Old 04-28-2008, 12:13 AM   #1 (permalink)
HATTENATOR's Avatar
Date registered: Jan 2008
Vehicle: 1988 190E 2.3
DIY Mercedes W201 190 Front and Rear Suspension including springs shocks struts
REAR SUSPENSION
First you will need to jack the car up and put it on a jack stand and remove the wheel. On some models you will also have to remove the plastic cover for the bottom arm,which is held on by 4 10mm bolt,arrowed 1 and 2 with another 2 on the other side of the arm
to change the shock undo bolt A,which is a 17mm head and nut,then undo bolt E,compress the shock and it comes out.
to remove the spring,put the jack under the bottom arm and raise it a little,then undo and remove the bolts in above diagram A=17mm B=13mm and C = 22mm
once you 've done that lower the jack and it should look like the picture below,push down on point D and the spring will literally fall out.
replacement is the reverse of removal
FRONT SUSPENSION
1) jack the car up and place it on a jack stand,then take the wheel off
2) to remove the strut, loosen and remove the bolts A,B and C which are 19mm,then loosen nut D using a 22mm wrench and (depending on make of strut) 7 or 8mm allen key, the strut is now ready to remove, you might have to push the strut up a bit to compress it enough to get it out, replacement is reversal of removal
To remove the spring
1) same as step one above
2) place the spring compressors on the spring as in the picture and tighten them up,now it is very important you do this evenally otherwise they could spring off and cause injuries.
3) once the spring compressors have been tightened up, this on other cars would be enough to get the spring out but on 190's the springs are so long and unless you have the proper mercedes spring compressors,you can't close the spring quite enough to get them out so
insert a long strong bar in between the the bottom arm and chassis marked ( 1) in the picture,at this point another to give you a hand would be press down on the bar (2) and use a screwdriver at point (3) to help pry it out,again fitting is the reverse of removal
Credit goes to Shrekky for pics and information contained in this post
Why dream of just any vehicle, when you can dream of owning one that was never imported.
HATTENATOR is offline   Reply With Quote
Old 04-28-2008, 02:55 PM   #2 (permalink)
w201 Über Moderator
Kynyption's Avatar
Date registered: Jan 2006
Vehicle: 1985 w201 Euro 2.3-16vlv / 1992 w201 2.6 Sportline Manual
Send a message via ICQ to Kynyption Send a message via AIM to Kynyption Send a message via MSN to Kynyption Send a message via Yahoo to Kynyption Send a message via Skype™ to Kynyption
Looking good.
Interesting holy rotor. haha
Added To FAQ
You Can Find Me In The w201...
...Don't Forget to Add Yourself To The w201 Frappr map!...
...Coming soon Projekt Euro
Kynyption is offline   Reply With Quote
Old 07-19-2008, 06:24 PM   #3 (permalink)
Date registered: Jul 2008
Vehicle: 1985 190D
That is a great post, thanks for taking the time, just did my rear shocks.
mbarbian is offline   Reply With Quote
KYB GR-2 STRUTS SHOCKS MERCEDES BENZ 190E 2.3 2.6 W201/HR Lowering Springs splitnrag For Sale, Trade & Wanted Items 6 06-10-2008 08:43 PM
Which Shocks/Struts/Springs to get?? RDM3 W201 190E, D-Class 6 05-23-2006 07:59 PM
FS - 2005 SLK350 sport suspension - shocks, struts, springs fgwinn For Sale, Trade & Wanted Items 3 02-08-2006 07:26 PM
Eibach Springs on 02 ML500 Rear Suspension DIY a02ml500 W163 M-Class 2 01-22-2004 09:03 PM
