» Site Navigation
» Other Sites
Old 04-07-2008, 09:04 AM   #1 (permalink)
raeanncherry
Date registered: Apr 2008
Unhappy Acceleration problem 1989 190E
Hi all,
I have a 190E (automatic) and am having some issues with acceleration and the speedometer. If I am in town at low speeds, there is some shuddering or roughness at low speeds and it won't accelerate even with the gas pedal is on the floor--does fine at higher speeds. Also, the speedometer needle either doesn't work at all or jumps around all over the place. Any help would be appreciated.
Thanks,
RaeAnn
raeanncherry is offline   Reply With Quote
Old 04-07-2008, 09:16 AM   #2 (permalink)
mfagus
mfagus's Avatar
Date registered: Nov 2004
Vehicle: 1987 TD Wagon
when was the last time car was tuned and fuel filter changed?
1987 300 TD Wagon
1984 VW Westphalia
1996 Kawasaki Vulcan Classic
1992 Infiniti M30 Convertible
2004 Nissan Murano
mfagus is online now   Reply With Quote
Old 04-08-2008, 12:17 PM   #3 (permalink)
lurk3r
Date registered: Mar 2008
Just had this, engine runs fine fast, won't come off idle ... fuel pump relay has a fuse on it, right in behind the battery.
lurk3r is offline   Reply With Quote
Old 04-19-2008, 01:15 AM   #4 (permalink)
Fix The Wire
Ask your workshop to check the OVP - Over Voltage Protection Relay.
That give lot of trouble after a while.
Fix The Wire is offline   Reply With Quote
1989 190e FS andrewk W201 190E, D-Class 24 07-02-2007 03:10 PM
1987 190e cold acceleration enrichment TV1 W201 190E, D-Class 1 12-29-2005 06:43 PM
Acceleration problem when warm 1989 420 SEL sali W126 S,SE,SEC,SEL,SD,SDL Class 13 07-05-2004 07:08 PM
1989 420 SEL - Acceleration problem when warm sali General Mercedes-Benz 1 05-31-2004 02:37 AM
acceleration with 190E 2.6L ymt W201 190E, D-Class 3 01-07-2004 10:12 AM
